Spider Top Frame Fix? | FerrariChat
Discussion in '360/430' started by jrcdds, May 3, 2017.
  1. jrcdds
    jrcdds Rookie
    Nov 16, 2014
    32
  2. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,528
    Charleston, SC
    Curt
    Isn't that made with magnesium forged from pure lava deposits of mount Etna? If so I doubt it. Would be interesting to see if a carbon fiber piece could be fabricated as a replacement.
  3. jrcdds
    jrcdds Rookie
    Nov 16, 2014
    32
    Well put and I am thinking so!
  4. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,753
    Boston, MA
    John E. Kenney
    Cool, go for it.
  5. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    It is magnesium and is weldable. It is also removable so you can replace it if you can find one.
  6. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    Has anyone repaired something like this before ?
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    I had the same thing on my last F430. It was replaced under warranty however I understand the root cause is incorrect adjustment in the roof or weakening of the elastic straps, which should be checked periodically.
  8. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    I bought my F430 with the same broken piece... I thought maybe someone pulled on it and cracked it... I was thinking maybe some type of super strong epoxy glue? But I never attempted to fix mine ..... yet
  9. jrcdds
    jrcdds Rookie
    Nov 16, 2014
    32
    Thanks to the reply's everyone!
    bocaf430, I tired a couple different adhesives and nothing worked at all....not even a little bit...
    mwstewart, good to know so once I do get it fixed I hopefully not have it happen again
    Stout, good to know
    Thanks again everyone!
  10. northsyd
    northsyd Karting
    Jun 11, 2013
    130
    white north
    chopper
    same thing happened to mine... I'll take a pic of the fix.
  11. hessank
    hessank Formula 3 Silver Subscribed
    Aug 8, 2005
    1,923
    Canada, Florida
    Fred
    Have you tried JB Weld?
  12. jrcdds
    jrcdds Rookie
    Nov 16, 2014
    32
    Nope, both where different versions/modifications of cyanoacrylates....neither did jack....guess I could try JB welb but that being said I think I finally got a line a on part from a member here so that should be even better if it pans out.
    The indy guys I know said its between 7-20K for a new frame (the part is not sold by itself) although the dealer gave me a quote for just over 3k including labor for new one.....crazy the dealer is quoting a frim fee that's way less that the indy guys....but cool for me, extra cool is the used part pans out good....
  13. blkdiablo33
    Jul 12, 2004
    4,454
    please share your fix
  14. jjsaustin
    jjsaustin Formula Junior
    May 11, 2008
    579
    Austin, TX
    Jim
    Same thing on my car on the driver's side. I wonder why this is a frequent issue and if they always fail on the driver's side.
    Someone said this is a removable part. When I last looked at this years ago, it did not look like it was easily removable, but maybe I'm wrong.
    If you could get this off, it would be easy to take to a weld shop to fix.
    It would be tough for glue to work unless you had some backing plate to help add strength.
  15. Stout
    May 9, 2013
    259
    Helotes, TX
    Victor
  16. David007
    David007 Rookie
    Jun 23, 2009
    33
    Scotland
    Dave
  17. David007
    David007 Rookie
    Jun 23, 2009
    33
    Scotland
    Dave
  18. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    pieces are aluminum. Can be welded and painted to match. I had both sides done over the years and still holding well.
  19. jjsaustin
    May 11, 2008
    579
    Austin, TX
    Jim
    Did you remove the pieces to have them welded?
    if so, any tips on removing them?
  20. blkdiablo33
    Jul 12, 2004
    4,454
    Can you please give details
  21. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    would like to know how to have welded also....welded on the car? or did they remove the part to weld it? thank you
  22. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    the parts were removed from the car. Welded, painted to match and reinstalled.
  23. jrcdds
    jrcdds Rookie
    Nov 16, 2014
    32
    Netman, do you happen to have any pictures of the repair??
  24. jjsaustin
    May 11, 2008
    579
    Austin, TX
    Jim
    I would be interested to know who removed the part and if this a DIY or not
  25. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
