SPIDER TOP IS STUCK | FerrariChat
SPIDER TOP IS STUCK
Discussion in '360/430' started by john.sulano, May 3, 2014.
  1. john.sulano
    john.sulano Rookie
    May 2, 2014
    2
    HOW DO YOU GET THE TOP ALL THE WAY DOWN ON A 2001 FERRARI 360
  2. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Check the fluid level. If this is good. Give the center of the roof a slap as it is folding back from the closed position. There is a center brace that is supposed to be collapsed flat by elastic that is rpown to failing due to stretching. If this is the case. The elastic can be replaced by an upholstery shop
  3. freefly_1
    freefly_1 Rookie
    Feb 3, 2014
    10
    Spain
    What's the problem with it? The roof operates in different fazes so depending on which part it's not working.
    Hydraulic fluid and trying to open and close it without the car running (low battery) are just some of the causes.
