spinner question | FerrariChat
spinner question
Discussion in 'Vintage (thru 365 GTC4)' started by Newman, Mar 30, 2009.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,447
    Canada
    Newman
    What car would have a 42mm spinner, engraved horse with an arrow but no word "off" in the arrow?
    Also is wire different from alloy in application?
  2. Telerding
    Telerding Formula Junior
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    Certainly the Daytona would have carried the spinner (knockoff) as you describe, in addition to those with the word "off". Probably C/4 as well
    US cars would have had an octagonal "knockoff" which required a large adapter to be removed.
    IF I understand your question, standard wire wheels and alloy wheels use same knockoff.
    Wider wire wheels and alloy wheels may require a different deeper knockoff.
  3. Newman
    Dec 26, 2001
    14,447
    Canada
    Newman
    #3 Newman, Mar 30, 2009
    Thanks but its still confusing. The ferrari original boxer spinner has an embossed horse and arrow. Its stamped not engraved. The replacement spinners from ferrari are engraved and have the arrow with "off" in it. The spinners im curious about have an engraved horse, no "off" in the arrow. Im not sure if any older cars had engraved spinners or if all newer ones were.
  4. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    I don't think the spinners change when the width of the rim changes, except for the different spinners used on some race-applications. The hubs are pretty much a uniform thing. A spinner suits a certain hub, 32, 42, 52mm and then of course L/H and R/H.
    I can't answer where the spinner belongs, but also bear in mind that there are replica spinners on the market, which may have small differences from the originals.
    Embossed? I'd think these are cast items, so the cavallino would be cast into/onto the spinner. (if not engraved)
    Man these things are beautiful! I'd love to have centre-lock wheels on my 308! Makes me think....would Boxer hubs fit...
  5. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    The 32mm KOs from the 60s seem to have the horse embossed on inserts
  6. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,580
    Grant
    My 1973 Daytona, came with the engraved spinners, and i have since bought a set of the embossed type. I don't know what was original but i guess it was the engraved ones, for my car. You do need different spinners if you have the 9 inch rear wheels, as the wheels are deeper dished, the lugs stick out more on these spinners, so you can hit them with the lead mallet more easily.
    Grant
  7. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Excellent point: I wonder how many beautiful Borrani's have suffered damage from a misguided mallet.
  8. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,792
    North Qld
    simon klein
    For those interested,I,ve just had a tool made(for my 365GT4 but I,m getting one made for the 330 as well) that depletes the need for smashing any part of your Ferrari with a lead mallet.Indeed you only need a socket bar and you can even torque them with a tension wrench.I,m going to the Ferrari nationals in Toowoomba(Qld,Aussie)in September to see if any other owners are like minded.The tool is as big as your spinner,will probably have a 3/4 drive socket hole and will probably come with a 1/2to 3/4 reducer extension.The costing is not final but will probably come in at/under $200 Aussie.The tool encompases the spinner giving grip on all parts of the ear.A mallet is the crudest part of any knock on spinner vehicle as most of you have found out.I know there are other tools on the market at about 200-400 euros but they don,t fit like a glove.Cheers,Simon.
  9. mdempsey
    mdempsey Karting
    Jun 6, 2007
    152
    Huntingtown, MD
    Mark P. Dempsey
    TS will know the answer for sure! TS?? I know that some replica spinners were produced that were not spot on for an original. I think that the 42 mm spinner was on many of the 2+2's (bigger heavier cars).
  10. michael bayer
    michael bayer Formula 3
    Aug 4, 2004
    1,292
    There is a thread here some years ago which I contributed a bit where we went through this, and as all things Ferrari, there are no fixed rules, at a National Meet BrianP was dinged for having straight eared knock offs on his alloys (in fact they were correct) and another car was passed with bent ears (not so for that model). If its not here, its on Tom Yang's, you can also check Kerry, he has the Borrani catalog which helps a lot.
  11. tazandjan
    39,159
    #11 tazandjan, Apr 2, 2009
    One of the old time tricks was to cast your own soft lead hammer around a handle using a cardboard large frozen orange juice container as the mold. The soft lead prevented damaging the knock-offs. They did not last very long, but a new one was easy to cast and most of the lead from the old hammer was reused. Casting was done in a well-ventilated room, probably an outdoor grill would be ideal. As you no doubt surmised, one use per orange juice container, since it was cut off the hammer head.
    Taz
    Terry Phillips
  12. ColdWater
    ColdWater Formula Junior
    Aug 19, 2006
    621
    bicoastal USA
  13. simon klein
    Feb 25, 2009
    29,792
    North Qld
    simon klein
    Mine is simillar but different.made out of mild steel(at the moment).These look a little fragile(probably are,nt) .Will try to put pic on here...see what you think
  14. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,580
    Grant
  15. simon klein
    Feb 25, 2009
    29,792
    North Qld
    simon klein
    G,day Grant,yes I,ve seen those check out the price though.Although we have the most exciting cars made we shouldn,t have to pay a premium price if we don,t have to.That thing is the equivalent of $500Aussie,my proposed price is probably closer to 1/2 that and has more contact with the ears of the spinner more will be revealed if I can get a pic on here.
  16. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,580
    Grant
    Hi Simon
    If you get stuck, send me the pic via e-mail and i will post it up for you
    Grant
