Splined hub torque. | FerrariChat
Splined hub torque.
Discussion in 'Boxers/TR/M' started by ago car nut, Feb 27, 2019.
  1. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Anyone know the torque value for the bolts holding the steel spline hub to the alloy wheel on 1987 Testarossa with center locks?
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    what you mean exactly? sorry for asking, but spline hib is a new word for me ;)
  3. ago car nut
    5,495
    Madison Ohio
    David A.
    The single bolt early testarossa have a splined wheel.
    turbo-joe likes this.
  4. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    thank you david. now I know what "splined" means.
    the translator says under splined in german also splined, but when I put in splined wheel the translator says "vielzahnrad", but even this is not correct. it must say "längsverzahnung", so splined means longitudinal gear teeth.
    always learning here in this great forum :)
    pshoejberg likes this.
  5. ago car nut
    5,495
    Madison Ohio
    David A.
    It is hard to get the true meaning of another language when translated!
  6. Steve Magnusson
    26,779
    I believe it is shown on page M7 of the TR WSM:
    "Screw securing flange to wheel 12 x 1,25 (M12 x 1.25P in English) 5 daN-m (36.9 ft-lb in English)"
  7. Rifledriver
    37,089
    And it is pretty important the condition of the surfaces those flanges are mounted to. One of the biggest reasons they are removed it to repaint the wheels. If there is a large build up of paint or an uneven surface due to the paint the hub flanges will "work", wear through the paint and end up loose.
    ago car nut, xplodee and turbo-joe like this.
  8. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
  9. Steve Magnusson
    26,779
    No, the OP is asking about the bolts holding the steel female spline piece to the aluminum wheel piece -- the 5-lug wheel lugbolts are an M14 x 1.5P size (and 72 ft-lb torque).
  10. kartboy1234
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    Ahh got it. Misread it at first.
    Sent from my ONEPLUS A3000 using Tapatalk
  11. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    That torque spec seems rather low considering the application and hardware involved. The WSM I have indicates 7.5 daN-m (~55 ft-lbs.).
  12. Steve Magnusson
    26,779
    #12 Steve Magnusson, Mar 3, 2019
    Yes -- my mistake, should be 7.5 (wrongly read the line below which is the same M12 x 1.25P size), but I had the M7 page right ;)
