Spring Tune Up Begins | Page 2 | FerrariChat
Discussion in '612/599' started by George Vosburgh, Mar 7, 2021.
  1. George Vosburgh
    George Vosburgh F1 Rookie
    So this driving season I'm planning on running Tubi mufflers with Fabspeed straight pipes. I got these mufflers from Daniel (DZ-96). If I don't like them for any reason I can always go back to the OEM mufflers.
  2. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,232
    Indiana/North Carolina
    JIM
    I”M SO JEALOUS!! I almost grabbed these. I figured you did it. :). They are going to sound amazing!
    George Vosburgh likes this.
  3. tazandjan
    39,020
    George- If nothing else you will have the prettiest 599 mufflers. You just need one of those rolling mirrors on a stick they use for bomb checks under cars to show them off. My buddies in the RAF in Germany used them all the time when the IRA was active. Luckily not an issue now.
    jimshadow likes this.
  4. George Vosburgh
    Yes, but you still can't see them because of the tray covering them. They better sound as good as they look! I do love the propeella tips.
    Skidkid likes this.
  5. Da Butcher
    Da Butcher Karting
    Jan 9, 2018
    214
    Jose Marie Alandy
    Unfortunately, CA (CARB) state regulators have issued a new law that will fail any automobile with non-OEM mods to emissions-related equipment, e.g. exhaust systems, upgraded ECU, etc. All cars need to undergo a biannual
    third-party DMV emissions inspection to renew license registration. Apparently, these inspections will now be able to compare the OEM emissions system equipment against and detect any unauthorized changes, additions, deletions by the owner.
    So CA owners will now only be limited to "cosmetic" upgrades, nothing else, unless the car will be declared for off road / track use only or for display.
    On the "cosmetic" front, my 2011 HGTE finally had its GTO grill installed and most of the sticky buttons replaced. I think the mesh grill fully integrates the 599's front fascia design closer to its "supercar" intent and away from its "Grand Touring" luxurious look.
    F3RN4ND0 and Makuono like this.
  6. George Vosburgh
    The grill looks fabulous! I have an original options book that came with my car and it has the GTO style grill as a standard HGTE option when ordering the car. I was not aware that this grill really isn't a modification on an HGTE. And in fact I have seen reviews on the HGTE with this grill in the pictures. On my standard 599, it's a modification.
    My buttons are really not bad but I'm thinking about it for this year.
  7. Da Butcher
    Da Butcher Karting
    Jan 9, 2018
    214
    Jose Marie Alandy
    Thanks George.
    My car looks so much better with the GTO mesh grill. I did see it offered on the 599 Options Book (2010, I think) along with the OEM longer CF Challenge gearshift lever (originally designed for the 458, but fits the 599) which I immediately had installed soon as I picked up the car. Allows me to switch gears during turns without moving my hands off its position on the steering wheel during exuberant driving.
    Cost to refurbish the sticky buttons was reasonable to my surprise, although F-SB used their own source in SoCal for expediency and better quality, at least according to the Service Manager. All in all with (FCA member) discounted prices for the grill, installation, r/r the sticky buttons, and labor came to about $2800.
  8. steve moody
    steve moody Karting
    92
    Cape Coral, Florida 33914
    steve moody
    Jose,
    Did you use paddles from Ferrari or another source? I want to do the same.
  9. George Vosburgh
  10. tazandjan
    39,020
    Mine has extended CF paddles from Carbonio, as well. Have had them about 10 years and not sure I could go back to standard paddles since they work so much better.
  11. jimshadow
    Feb 19, 2006
    6,232
    JIM
    Are 599 and F430 paddles (aftermarket) essentially the same or different?
  12. George Vosburgh
    I've never seen them marketed as one in the same. I have seen the Auto and Reverse buttons listed for both models.
  13. Da Butcher
    Da Butcher Karting
    Jan 9, 2018
    214
    Jose Marie Alandy
    Steve,
    As Taz and George both noted, I also both mine from Carbonio about 4 years ago and it cost about $950 then.
    According to the Carbonio literature, they're essentially designed for the 458 Challenge cars but fit perfectly on the 599 with relatively easy installation using angled allen wrenches and a certain technique to slant the steering wheel for access to the paddle screws on the right side of the steering column.
    I'm certain they're available from Ferrari because I saw them on the 2010 599 Options Book, but the price may be (or are) much higher. I can't tell the difference in design and construction.
    FWIW if you're quite meticulous with minute details, I did notice that the CF matrix orientation was about 90-degrees offset from the matrix orientation of my 599 HGTE's CF steering wheel. Regardless, while sitting on the seat I couldn't detect that difference in patterns, plus I'm not sure if the Ferrari 458 CF paddle version has its orientation matched to the steering wheel to begin with. It doesn't matter functionally.
  14. George Vosburgh
  15. tazandjan
    39,020
    George- Those are standard length.
  16. George Vosburgh
    I thought the GTO came with the extended paddles, sorry.
  17. Da Butcher
    Da Butcher Karting
    Jan 9, 2018
    214
    Jose Marie Alandy
    My HGTE came with the standard CF paddles, same as the GTO's. The bottom section was truncated unlike the 458 Challenge paddles.
    I did keep the original HGTE CF paddles, as well as its original Alcantara floor mats (a bit used up) and original special front grill.
    If I did decide to run my car through the FCA Concours Competition, I wonder if it might get a hefty deduction from judges. That is, unless I can convince them the Challenge paddles were available as an OEM aftermarket option via the Ferrari 599 Options Catalogue published in 2010.
  18. Skidkid
    Skidkid F1 Veteran
    9,492
    Campbell, CA
    John Zornes
    Yep, my HGTE has CF paddles.
  19. George Vosburgh
    So this season I'm running a Tubi exhaust with straight pipes and stock headers. The sound is not as raspy as the stock mufflers with straight pipes which I'm happy about. The pitch is much deeper and there is a little more drone in the cabin but that also means I'm hearing more engine. The engine is even more free flowing than with just the straight pipes. You get some nice burbles when down shifting. No, it's not as good as Fabio's set up but for the money I'm pretty happy with it and you can't beat the look of the propella on the exhaust tips. Image Unavailable, Please Login
    Autobahn-Outlaw and Nospinzone like this.
  20. tazandjan
    39,020
    George- Similar to HGTE tailipes except the dividers are slanted like a turbine. Look good.
    Skidkid likes this.
  21. DZ-96
    DZ-96 Formula 3
    1,890
    South Germany
    Daniel
    Hi George
    Fine that you like them.
    Daniel
  22. Skidkid
    Skidkid F1 Veteran
    9,492
    Campbell, CA
    John Zornes
    Yes, I like the HGTE exhaust. The pipes look great and those are very similar. Much nicer than stock exhaust tips.
    DZ-96 likes this.
  23. George Vosburgh
    They're great Daniel, thanks again!
    DZ-96 likes this.
  24. George Vosburgh
    Thanks Taz, these remind me a lot of the HGTE sound at start up.
  25. DZ-96
    DZ-96 Formula 3
    1,890
    South Germany
    Daniel
    Like John said, stock end tips looks not really nice.
    HGTE or Tubi Propella much much better.
    I never had the direct comparison with stock headers between stock mufflers and Tubis.
    One time i heard HGTE mufflers, these are incredible in sound.
    I think Fabio's 6-1 with cats, the special designed small silencers Fabio made for me and HGTE mufflers would be the optimum in sound and look.
    High pitch and not too loud.
    Daniel
    Skidkid and George Vosburgh like this.
