Spring Tune Up Begins | Page 3 | FerrariChat
Discussion in '612/599' started by George Vosburgh, Mar 7, 2021.
  1. Skidkid
    Skidkid F1 Veteran
    9,634
    Campbell, CA
    John Zornes
    I am VERY tempted to go exactly this way.
  2. DZ-96
    DZ-96 Formula 3
    1,926
    South Germany
    Daniel
    You should do it.
    You will NEVER regret it.
    Daniel
  3. tazandjan
    39,318
    Those HGTE/Tubi tailpipes also stay a lot cooler and cleaner on the outside.
    George Vosburgh likes this.
  4. rynoshark
    rynoshark Formula 3
    1,035
    Pacific Northwest
    Mine has the Tubi straight pipes kit 01410461000 (without the standard tips instead of Propella tips). It is almost too loud...I need more time driving it this season to see if I will take the cat-back straight pipes off and fit Tubi or HGTE mufflers.
  5. George Vosburgh
    George Vosburgh F1 Rookie
    I think these are great if you are making a track car but around town it might be too much.
  6. rynoshark
    rynoshark Formula 3
    1,035
    Pacific Northwest
    Yes...so far, it has been a bit loud :) It does draw a lot of attention to the 612 though.
  7. DZ-96
    DZ-96 Formula 3
    1,926
    South Germany
    Daniel
    Good engine sound has not to be loud.
    Present but not loud.
    Daniel
    Makuono and George Vosburgh like this.
  8. George Vosburgh
    So I put the Tubi mufflers on the car with the Fabspeed straight pipes. I ran it around for a couple of weeks and decided to pin the flaps open, not to make it louder but to get rid of the transfer from closed flap to open flap. So far I think this is a great improvement. It's louder in the cabin when shifting but once you get to 6 and cruising there is no problem. Plus, as I have mentioned before, there is more connection to the engine sound which I personally like.
    jimshadow likes this.
  9. Kyle Stoffer
    Kyle Stoffer Karting
    Sep 23, 2019
    82
    Kyle R Stoffer
    I did the exact same thing. I’ve got an HGTE, stock mufflers but added the Fabspeed cat delete, disconnected the vacuum tube to the valve so that it stayed open permanently. Much better, and startup/idle is glorious.
  10. George Vosburgh
    Taz, I think this is some kind nod to the 250 SWB. Same propella.
  11. tazandjan
    39,318
  12. George Vosburgh
    This year's tune included:
    New Front Shocks (OEM)
    New steel braided brake lines
    New trunk and gas cap buttons treated by StickyNoMore
    New Reverse and Auto buttons by Sticky RX Solutions - these are very nice!
    Full Clay and Ceramic Coat (Adams)
    Full 2 step Leatherique process complete interior
    Fluids as prescribed for years and mileage
    Motor mounts checked
    F1 lines checked
    I'm done, time to drive!
    brogenville, Skidkid and 599_GTO like this.
  13. George Vosburgh
    One more addition: a belt pulley tensioner, which was ordered, was installed today. The car was making a little squeaky noise when it was cold, not any more.
    Skidkid likes this.
  14. George Vosburgh
    So this year's big preventative item is the oil breather check valve #265721. This valve tends to leak all over the corresponding hoses around it and is the cause of many a 599 fire. Ferrari is apparently aware of the problem and now has an upgraded kit. The theory is that the valve is weak and if the car is overfilled with oil the oil expands and pushes out of the valve.
    Cam Solenoids checked
    Caliper pistons checked
    Clutch life 56% used on 47K miles
    More sticky buttons replaced with treated buttons
    F1 transmission fluid changed (every other year)
    Oil service
    General engine bay cleaned
    PA Inspection
    Ready to Roll!
    Nospinzone, Skidkid and 375+ like this.
  15. 375+
    375+ F1 World Champ
    13,883
    Rock-on George!
  16. Skidkid
    Skidkid F1 Veteran
    9,634
    Campbell, CA
    John Zornes
    You are my hero! I have a very long list of stuff to do on my car. I decided to PNO (planned non-operation) the car and do the lagging stuff. I will get busy on it after taxes are done, until then it is on my lift.
  17. steve moody
    steve moody Karting
    94
    Cape Coral, Florida 33914
    steve moody
    I have just done most of the same stuff to my 09. It will crack 10K miles in the next week. I changed the rear shocks with new ones and will have the rears rebuilt to put on the front when those start to leak. I think I will install new engine and trans mounts and brake hoses when it gets too hot here. These were punch list items when I had my car at Ferrari of Naples for an inspection.
    Skidkid likes this.
  18. George Vosburgh
    It's interesting that so many people need to do the motor mounts, mine continue to be fine. I haven't done the rear shocks yet because they continue to behave.
  19. George Vosburgh
    Today I started the annual Leatherique slathering. I hate the process but love the results.
    JLF and Skidkid like this.
  20. George Vosburgh
    And once again I started the annual dreaded Leatherique slathering. I have a new dash that I plan on taking care of so that was first today. Windows closed, heat cranked in the garage, I'll take it off tomorrow.
    FastMev and Imstillonjava like this.
  21. Anthony James
    Anthony James Formula Junior
    365
    Essex
    George, you leave it on over night? I'm about to do my annual service, and that's the product I used on the interior. I never left it on over night, But will try that if you have had better results. P.S. Did you also cat delete the 612?
    Cheers
    Anthony
  22. George Vosburgh
    This time I left the conditioner (part 1) on for two days with the heat up in the garage and windows closed. I've heard people putting it on the seats and placing the seats in a plastic garbage for weeks! The longer you leave it on the more of it gets into the leather. I think my seats are softer now than when they were new. I do the entire interior in sections, dash, seats, parcel shelf and side pieces. My car is a 599 and yes the cats are off plus tubi mufflers. Good luck!
    Anthony James, Skidkid and bamaman like this.
  23. George Vosburgh
    So the final bit of tune up for this year:
    Coolant Flush
    New F1 Fluid
    New Gear Box Fluid
    Brake Fluid Flush
    Oil Change
    This on top of the new dash wrap with new windshield vents.
    It was a lot this year, but the car is perfect. All of the fluid changes are according to the manual's schedule.
    FastMev and 375+ like this.
  24. MrS
    MrS Karting
    Mar 31, 2023
    52
    Silverstone
    Mr S
    This sounds amazing, do you not need to deal with white clumps or build up in the crevices at all? I have a 2 part cleaner and conditioner i normally use, but as im quite new to the 599, iv yet to do it. I have Daytona seats in Black with red stripes.
  25. George Vosburgh
    MrS likes this.
