Sprung a leak (probably my fault) | FerrariChat
Discussion in 'Technical Q&A' started by Dr Kananga, Mar 24, 2012.
  1. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    I was under the car yesterday, putting on the coolant pipes I refinishes and coolant hoses and I noticed a subtle leak developing at, both, the engine and tranny sump covers.
    I did take some cleaning solutions (mostly Simple Green) to clean up under there (there was never a leak before, just incredibly filthy).
    Is is possible I have compromised the seal at the gasket?
    I did the same cleaning on the engine head covers.
    Do I have to be concerned about a potential geyser of oil spewing out, on to the engine, probably causing a fire whilst driving?
    I can't imagine pulling off the covers (tranny and engine sumps, heads) and replacing the gasket + seal is that difficult... or, is that a rookies mind "working"?
    Please advise.
    Thanks!!
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Doc, what's leaking oil or gear oil or coolant?
  3. Cribbj
    Cribbj Formula 3
    Caked on grease and road grunge can be an amazingly effective "Stop Leak" sometimes :)
    If it's leaking with a cold engine, and without the engine running, it'll probably only get worse when the fluid heats up, thins out, and is under pressure.
    Wouldn't think you'd have a geyser kind of leak, but I'd definitely keep an eye on it and for puddles wherever you park, and perhaps carry a spare quart or two of whatever is leaking until you get it sorted.
  4. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    Pictures!?!??
  5. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    Just come over!!!
    HAHAHAHAHA
    I shall post when I get back to the car.
    Sent from my iPhone
    (which probably means I'm sitting at my car confused)
