Sputtering with a 512TR? | FerrariChat
Discussion in 'Boxers/TR/M' started by Soundguy, Aug 6, 2004.
  1. Soundguy
    Soundguy Rookie
    Aug 6, 2004
    42
    Just took delivery on a 92 512 TR
    The car is beautiful. EXCEPT It bucks and jerks just after a few minutes of starting the car.
    The dashboard warning lights that tell you to slow down because cylinders 1-6 or 7-12 are not working correctly keep coming on?
    I've relaced the O2 sensors in the catalytic convertors today, but nothing has changed.
    Anybody have any ideas?
    Help???
  2. Steve Magnusson
    26,828
    I think you're already looking in the right area (something is wrong when it tries to run closed-loop after warming-up using the O2 sensor output signal), but just to reconfirm that you might try just unplugging the O2 sensors when warm and see if things smooth out somewhat. Usually these O2 controlled injection system are designed smart enough such that when it can determine that no O2 signal is present it will default back into the "dumber" cold-running mode.
    Did the car previously run well warm? You don't give much background so you might reverify that the 1/6 O2 sensor is connected to the 1/6 injection control unit, and likewise for the 7/12 side -- did you just put a new exhaust system on it where who's-who might be mixed-up? I know that putting a Tubi on my TR required moving the O2 sensors around physically to keep things right.
    Getting exhaust overheating indications on both banks is a little unusual based on the split injection architecture...
  3. Rifledriver
    37,108
    The O2 sensors only modify the base line setting, unplugging them does not return it to a cold operating condition it allows it to return to an un modified state. But you are correct, unplugging them will eliminate them as a cause. If hooked up backwards it will be a disaster, but I dont think that the wires are long enough on a 512TR to do that. The ck engine lights (if those are the ones that came on) indicate that something has been registered in the computer memory and can be accessed easily.That should be done before you spend any more money throwing parts at it.
  4. Steve Magnusson
    26,828
    I was referring to the cold operating situation as an "unmodified" (open-loop) state so I don't understand your distinction...
    PS shouldn't a Moderator move this thread into the "Classic" section?
  5. Rifledriver
    37,108
    There are a host of differences in a cold versus hot operating condition. There many inputs to the motronics several of which are temp related. The o2's are not one of them in the strictest sense. The The o2's go off line (open loop) in a couple of situations not necessarily temp related and their going to open loop does not return the motor to cold operating mode. In any event I made the statement to bring a little more precise information into the conversation, not just in an effort to correct you.
  6. Rifledriver
    37,108
    I'm sorry that I forgot to mention the most important thing. If the lights that are coming on are the slow down lights that is an indication of the catalytic converters overheating and the motor should not be allowed to run very long in that situation. The cats can get so hot they can set fire to the car, (I've seen it happen) and even on a much less severe overheat the cats themselves can be destroyed, Very $$$$. At this point it may be less expensive to get it to a shop experienced with those cars.
  7. Soundguy
    Soundguy Rookie
    Aug 6, 2004
    42
    Steve:
    I bought the car from a dealer in PA. And he told me he drove it a week before delivery and thing s were perfect. (yeah right)
    The service records indicate a full 30K service was done a thousand miles ago (car has 29K) at ALGAR in Philadelphia.
    Anyhow, It never has run correctly since the day I got it last week.
    Now the dealer will take it back and have Algar look it over again, but I though if it was something easy I could do it here in New York.
    After all I want to drive the car. But that does not seem to be a reality, now.
    I bought new O2 sensors and installed them. With no change at all?
    And this morning I unplugged the O2 sesnors completley.
    Although the car seemed to idle better, it was not searching for an idle speed, as soon as I drove the damn thing it started backfiring etc...
    Now the guys at Miller Motor Cars, and Algar tell me that I might have to change the "PROBES" also?
    Paul
  8. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    A long shot but have you tried disconnecting the battery for a minute and then retrying? It resets the system and works on my 512TR for a few months when a yellow light comes on for a particular bank. Your problem sounds different but its worth a shot. By the way , disconnect the battery cable not just turning the switch off.
  9. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,985
    MO
    Omar
    Moved to classics.
    As far as I have seen, sputtering means mostly either old gas or dirty plugs.
  10. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Hmmm, my road 512 is doing that, could be you need new spark plug wires, or check the plugs
  11. RP512TR
    RP512TR Karting
    Jan 11, 2004
    135
    FRESNO
    Ross
    I have a 92 TR and i have had the same problems. It could be a number of different things my problem was bad spark plugs and i had a burnt valve. good luck with finding the problem.
  12. bear575
    bear575 Rookie
    Nov 10, 2003
    15
    you make no mention as to when the service was actually done.....last year? five years ago?
  13. Soundguy
    Soundguy Rookie
    Aug 6, 2004
    42
  14. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    793
    Sydney Australia
    Anthony
    how can replacing CATS affect the cold start problems?
    I don't understand.
    Cats aren't even in the loop when engine is cold.
    So when you didconnected the O2, you had the above quote, well then your problem has nothing to with Cats or O2s then. Once you have disconnected the O2 sensors, the motronics will stop using them to calculate fuel metering.
    It will rely on your TPS and Hotwire AF.
    Also check your FPRs vacuum line for unmetered fuel going back into the inlet manifold.
