Spyder battery finally died! | FerrariChat
Discussion in 'Northwest' started by StoryBook, Jan 5, 2004.
  1. StoryBook
    StoryBook F1 Rookie
    Mar 1, 2003
    4,304
    PNW
    MPL
    Left the 360 spyder idle for 2.5 weeks and finally wouldn't start. Battery was dead as a doornail. Stockpro came over and helped me jump it with cables.........after getting the connections correct, she fired right up. That damn battery is in such a ridiculous spot........behind the passenger footwell?? What the hell were they thinking! Spent the rest of the afternoon giving her some loving around town!!:)
  2. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    From various reports here on FChat, it seems like 2.5 weeks idle, without the battery tender, is about the life limit for the battery in the 360. I don't leave my car sitting that long so it's still good.
    What about just starting the car every 2-3 days? I think that might help.
  3. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    Just starting it won't charge the battery. Actually, that will draw down power. Best bet is to start her and drive it.
  4. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Oh, yeah. Forgot about that. I guess the best solution would be to use a battery tender then.
  5. StoryBook
    StoryBook F1 Rookie
    Mar 1, 2003
    4,304
    PNW
    MPL
    Jumping it from the Rover worked just fine........after getting the connections right of course.
  6. f355spider
    f355spider F1 World Champ
    18,033
    Andrew reviewed the F-chat archives and said that it may be a combination of the current draw of the 360 while sitting idle (parked, turned off) and the so-so quality of the Fiamm factory battery. So, either use the battery tender, or get a Optima battery. Or do both. Or as Willis does, drive regularly.
  7. TimF40
    TimF40 Formula 3
    Nov 3, 2003
    1,035
    Seattle/Bay Area/NYC
    Tim
    Doesn't anyone just turn off the master battery switch as per the manual? I assume you'd lose the radio presets, but so what. The manual just says to let the ECUs calibrate for 10 seconds after turning everything back on. It seems simple and a great solution for another month or so of shutdown (if needed)?? - Tim
  8. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    Searching the Fchat archives I noticed that several people have recommended Optima Red Top batteries over the OEM Fiamm. However, Optima has confirmed that they don't make a battery that will correctly fit the 360 as the car's specs require a shorter battery. FWIW, FoS recommends using Interstate batteries for two reasons... proper fit and longevity over the OEM and Optima batteries.
  9. StoryBook
    StoryBook F1 Rookie
    Mar 1, 2003
    4,304
    PNW
    MPL
    Glad we found out that the optima won't fit before buying it. Any harm in just keeping the original battery until spring when the auto is driven more. I'm thinking of doing what Tinslow suggested. Anything else lost besides just radio presents?
  10. f355spider
    18,033
    Doubtful, other than the hassle of waiting 10 plus minutes and resetting the clock and radio presets. Can't you run an extension cord for the battery tender?
  11. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    You need to punch in the code from the radio manual package. That's about it. I didn't bother doing that after I turned the power off up at Whistler. Don't use the radio anyway. :)
  12. StoryBook
    StoryBook F1 Rookie
    Mar 1, 2003
    4,304
    PNW
    MPL
    Was that 10 seconds or 10 minutes? Sorry haven't really read the manual.
  13. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    definitely remember to have your radio security code handy before disconnecting power.
  14. TimF40
    TimF40 Formula 3
    Nov 3, 2003
    1,035
    Tim
    *seconds*
    The only other thing was that the intake temp had to be above 41 degrees or thereabouts. Not normally a concern, but given the recent weather! ;-}
  15. f355spider
    18,033
    Wow, 10 seconds is way better than the earlier cars...which require 10 minutes or so.
  16. mw575
    mw575 F1 Rookie
    May 30, 2001
    2,924
    Lake Oswego,Or
    Martin J Weiner,M.D.
    When we go to Ca we leave the mini cooper S hooked up to a trickle charger.(for 2 mo).The 575 came (for $850-duh) with a battery charger and attachment in the engine compartment and I have it attached all winter here in the NW.The 360 batteries are notoriously weak.
    Kuzt-That battery compartment in the passenger footwell in your 360 opens up in a few sec's (2 screws).You should buy a trickle charger ($35-$60) and leave it attached especially during this cold spell.
    Just running the engine will do zilch.
  17. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    Kuzi's spyder does have a trickle charger. Probably not a bad idea to run an extension cord and to the charger to maintain battery life. Otherwise we may be using the Rover to do a lot of jumping.
  18. shelbee
    shelbee Guest
    Mine almost won't start but it was fine after three tries. But I will replace the OEM battery with Optima, like what I did with my 550. Never had problem although I did not start the car for 3 weeks and left it on all the time without starting the car.
    Here is the info where to get the Optima battery,
    http://www.1st-optima-batteries.com/
  19. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    Let us know if you get the Optima to fit in the 360. According to Optima their batteries are too tall to properly fit. Will be interesting to find out.
  20. StoryBook
    StoryBook F1 Rookie
    Mar 1, 2003
    4,304
    PNW
    MPL
    Anyone know how to turn the 360 into a 4x4. Seems thats the only way to get around these next few days.
  21. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    Sure, just go get yourself an Audi RS6 or S4 or you can always wait for the RS4 to come out. :)
  22. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    RS4's have already landed. I have a friend that got one last year.
  23. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    That must be a B5 RS4 you are referring to since the new B6 RS4 does not exist just yet. The B5 RS4 were never Federalized for US market, heck of a car tho. I believe an Audi tuner here in Seattle had somehow imported a couple of them into the States a little while back. :)
  24. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    You're right, it was a B5 RS4. My friend, Josh, who owns Actuning! in Redmond imported a couple last year. Not sabby for a grocery getter. :)
  25. Scotty
    Scotty F1 World Champ
    10,398
    Oregon
    Scotty Ferrari
    My battery died about two weeks ago. Ron Tonkin recommends a Interstate battery as well--noting that it is cheaper, vented, and fits easily. They only keep the stock FIAMM on hand for warranty claims. FWIW I took the FIAMM into GI Joes and physically compared it to all of the Optimas--nothing is the same size, and further the shape of the case (due to plastic molding around the terminals) would seem to make it a difficult fit (and more difficult to secure) in the stock battery holdown. I'm sure there are creative solutions to make it work, but I'm going for the Interstate. (Optimas are sealed, so the vent tube issue isn't a problem). Of course, RTGT hasn't seen the Interstate delivery truck all week, thanks to the weather. Bummer.
