square cut gears | FerrariChat
square cut gears
Discussion in 'Technical Q&A' started by Classiche, Oct 7, 2013.
  1. Classiche
    Classiche Rookie
    May 11, 2013
    2
    Does anyone run square cut gears in their Ferrari? I think the sound will complement the impressive sound of a Ferrari. I am thinking of doing this to a Ferrari 308 along with custom exhaust. Thank you very much for your time.
  2. EfiOz
    EfiOz Formula Junior
    Jul 26, 2005
    850
    Lago di Legana
    Lucivius Maximus
    I think you mean straight cut gears. The noise will drive you nuts.
  3. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I dont know if there is something available for the ferrari gearboxes. But if you should search for sequential shiftet or dog type gearboxes. Because those gears are used in these gearboxes. Hewland f.e. builds custom gearboxes and you can get a gearbox done by them.
    But inside the car you will most likely only hear that high pitch noise it will overvolume any other sound when speed raises. You dont hear the engine you dont hear the exhaust you dont hear the radio you dont hear outside anything just those high pitch noise. Testdrive a car with such a gearbox befor you consider building a straight cut gearbox into your car.
    When customer have such gearboxes and i need to map or testdrive them i use earprotections with communication system to speak with the driver during mapping. I dont think that would be "fun" in a street car. But tastes are different but i would test it to see if it is ok. There are also semi straight gear sets these are a bit less noisy.
  4. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Good luck with it. Let us know how you make out with your custom designed and built gearbox. Sounds like a cheap and easy project.
  5. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    All that will do is make you explain that there is nothing wrong with your car everytime you pull up somewhere in front of people
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    "What's that noise? I paid extra to make it sound like that"
  7. lonestarrpm
    lonestarrpm Karting
    Aug 26, 2013
    57
    Austin, Texas
    Lone Star RPM. LLC
    I have it in my Porsche 911 race car -- sounds awesome -- but then again its a race car.
    It's loud and will drown out just about all other noises.
  8. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Interesting user name and first post...
  9. Statler
    Statler F1 World Champ
    Jun 7, 2011
    17,389
    <Ducati dry clutch>
  10. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    Collotti makes a full mkit for everything from a 375 or a 290MM to an F430....
    GTO, LM, 512S,,,you name it, they built them...
  11. Classiche
    Classiche Rookie
    May 11, 2013
    2
    Thank you for all of your replies. Yes, I meant straight cut gears. Long story short, I like the noise the gears make. Is it possible to have a hybrid set of gears? Straight cut gears in the low gears and traditional gears in the high gears. That way it sounds normal at highway speeds.
  12. EfiOz
    Jul 26, 2005
    850
    Lago di Legana
    Lucivius Maximus
    Modena Engineering in Melbourne also do straight cut gear sets for Ferraris.
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    P 4/5 C has straight cut gears. Sequential Hewland. When I drive it I always use hearing protection. If you don't you will damage your hearing. We're going to use the same gearbox in our next road and race car but in our next road car we're making helicoidal gears that will be quieter. As an aside our gear box is a good 50K euros. With custom gears/spares and tools more. Great gearbox for racing as it's very strong but straight cut gears aren't needed on a road car. My 60ies Le Mans cars have straight cut gears as well but we've taken the edge off of the gears a touch by hand honing/beveling which quiets them a bit and makes them tolerable on the road. It also makes them a lot easier to shift. The Hewland has a sensor that cuts ign and throttle for a millisecond when you shift so you don't need to use the clutch but on the road I use the clutch.
    There are shops that can make any gear you want any way you want them to be. We can as well BUT the cost is mega.
  14. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    Wouldn't it be easier to fit a set of aggressive mud tires and put some playing cards so that they flap in the wheel spokes? I loved that noise when I was a kid riding my bicycle.
  15. myronx19
    myronx19 Formula Junior
    May 27, 2012
    653
    Toronto, ON Canada
    Myron Samila
    #15 myronx19, Oct 11, 2013
    Unless you're in a race car... I doubt you'll like it.. And first gear would most likely be as low as a regular 2nd gear ratio, which is kinda tough to use on the street. If you're not convinced, listen to when the gears get loaded in this video.. make it a sequential while you're at it :)
    [ame=http://www.youtube.com/watch?v=eSJ-HzNWJGM]SCary BMW E36 race car.O my god! damn fast - YouTube[/ame]
    and I'll leave these right here....
