Squeaking 355 Brakes!!! | FerrariChat
Discussion in '348/355' started by HankCarp, Jul 3, 2007.
  1. HankCarp
    HankCarp Formula Junior Sponsor
    Aug 11, 2006
    591
    Fort Lauderdale, FL
    Hank Carpenter
    355 Squeaking Brakes... Any suggestions? I just had them replaced and they seem to be getting worse!
    Thanks for the suggestions!
    Hank
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #1, 348 and 355 brake pads are directional. Install them backwards and they'll squeak.
    #2, warped rotors will squeak. Get them turned down.
    #3, you want brake pads that aren't prone to squeaking such as Axxis Metal Master pads.
  3. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Mine squeak like hell too (but only sometimes), not sure what pads are on them. I've lived with noisy race pads on other cars so I don't mind too much...
  4. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,053
    Hank, what pads? The factory ones are known to squeal pretty bad. I would recommend the Porterfield R4S, though there are other good pads out there too. I've used the Axxis Metal Master in applications other than Ferrari and they worked pretty good and did not squeal.
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    AXXIS pads are the best!!! Low dust, No noise, don't need warming up and don't fade......!!!! Everyone whom I recommended these to, loves them and has thanked me for the tip :)!!
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I wouldn't and don't use anything else. The porterfield pads were supposed to be great, but recently they changed the R4S chemical compounds and in so doing screwed the pooch.
    No reason to use the new Porterfields at $100+ when the old Axxis pads at $50/pair are better.
  7. HankCarp
    Aug 11, 2006
    591
    Fort Lauderdale, FL
    Hank Carpenter
    Thanks gothspeed!
    I'm going to find out on Thursday what type of pads they used. I'm also going to get them changed to Axxis Pads if that's not what they used. I don't think I could get used to it... There is nothing like pulling into a crowded parking lot and everyone is looking at you when you pull in and then you hit the brakes and it scares the heck out of everyone!!! Mine are very loud and it's really embarassing...
    Thanks for the tips!
    Hank
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :D :D :D
    You will not regret it!!!! Don't let anyone talk you out of them and into spending more money on others...... if you don't like them I will buy them from you!!! Just make sure they are genuine AXXIS they have a "metal master and deluxe" either is good but I prefer the Deluxe, they don't wear your rotors as much and work just as well :)
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Get the rotors turned down at the same time that you swap pads. Warped rotors will squeak (and potentially ruin) even the best pads.
    No connection to them, but for whatever it's worth I buy my Axxis pads from here: http://www.buybrakes.com/store/45-06080M
  10. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,461
    Winston Salem, NC
    Honestly, where do you get your information? This is absolutely not true, and I spoke with Tim Porterfield about it in detail yesterday. The R4S compound has not changed whatsoever.
    Porterfields are $85 per box, 2 boxes will do the whole car.
    Hank... you're local to me. Come on over and I'll give you a set gratis for your car.
    Regarding Axxis pads, I run Axxis Deluxe Plus in my daily drivers, and they are good pads -- very very low dust. In my opinion, they are not stout enough for the way I drive my Ferrari so I'll stick with Porterfield, EBC, and Brembo as the brands of choice.
  11. HankCarp
    Aug 11, 2006
    591
    Fort Lauderdale, FL
    Hank Carpenter
    Thanks Daniel!
    I'm going to check and see what they used on my car since I just had them replaced 3 weekd ago. I'll get up with you next week...
    Hank
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Do you sell AXXIS pads for 348/355??
  13. Ricambi America
    Dec 7, 2003
    16,461
    Winston Salem, NC
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    http://www.ferrarichat.com/forum/showthread.php?t=156023
    Posts 1, 3, and 10.
  15. Ricambi America
    Dec 7, 2003
    16,461
    Winston Salem, NC
    OK, but that doesn't make it any more true.
  16. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Whoaa.... that is where I bought my set :D!!
  17. DannyR
    DannyR Karting
    Apr 6, 2005
    129
    Alabama
    Danny Roberts
    Hank,
    Bought my 355 s few months ago. It had the stock brakes. They were in good shape but sqeeked and squeeled and left SO much brake dust.
    I swtiched to the Porterfeilds and instantly the problem was solved.
    Very good stopping, no noise and no dust.
    Danny
  18. jakermc
    jakermc Formula 3 Owner
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    +1 Porterfield R4S. Great street pad for the aggressive driver. No noise at all, though I did put some 'anti-squeek' compound on the backing plates to make sure I didn't have a problem. My stock pads were horrible, I replaced them despite having lots of meat left.
    The R4S will not hold up to real track use however. A fast driver will over heat them in just a few laps.
  19. Ricambi America
    Dec 7, 2003
    16,461
    Winston Salem, NC
    Correct. Porterfield offers R4 for the track, and there are additional track compounds such as R4E depending on the event you're running.
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Try the AXXIS deluxe.... unless you are going racing they are the best IMO..... As I said if you don't like them, I will buy them from you... and everyone reading this is witness ;).
  21. f355spider
    May 29, 2001
    18,053
    Okay on this I have some personal experience....DO NOT USE THE AXXIS DELUXE PLUS on your 355! (Btw, there are three or four different formulations that Axxis makes, the Deluxe, Deluxe Plus, Metal Master and Ultimate. Each is a step higher in braking performance.) I have used the Deluxe Plus on my previous 87 328 GTS and they worked quite well, along with upgrading to Goodridge stainless steel braided brake lines. (I I even had them installed on my BMW 540 M-Sport "daily driver") But I do not think these pads would be appropriate for a 355. I did install the Porterfield R4S on my 355 and noticed an immediate improvement in initial "bite" and better pedal feel, and modulation. Since then, I have had three friends with 355's also install R4S and have also been very pleased with the improvement. I will install R4S on my BMW very shortly, as I like them that much.
    If you must use Axxis, go with the Metal Master, they are a decent pad, at least equal to the factory oem 355 pad. But understand it is a very old design, heck I used them in my souped up VW Rabbit back in the early 1980's! ;) But I continued to use them up until the late 1990's. I hear the Ultimate can have squeal issues, but I have no personal experience with them, so take that with a grain of salt...
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    They were called repco in the 80's...... they are made in Australia that should end all concerns right there.... right Pap???? ;)
    BTW Mr. Rection are you offering a buy back on the porterhouse pads???? ;) ;)
  23. f355spider
    May 29, 2001
    18,053
    +2 I bought my pads and stainless steel braided lines for my BMW 540 from Dave Zeckhausen too!! He's a great and helpful person, just like Daniel at Ricambi! :)
  24. Ricambi America
    Dec 7, 2003
    16,461
    Winston Salem, NC
    Zeckhausen is a neat little operation. It's funny how we could all probably get our Axxis pads at a big retailer, but choose to deal with an enthusiast like Dave. The price might even be higher at Zeckhausen, but it's fun to deal with fellow Bimmer heads and he'll get my business as long as he's around. Next step: Deluxe Plus for my Mini Cooper, which dusts like there's no end in sight.
