Squeaky 348 front suspension (not brakes), Anyone had this problem | FerrariChat
Discussion in '348/355' started by tbsb9595, Apr 18, 2008.
  1. tbsb9595
    tbsb9595 Guest
    Sep 19, 2006
    105
    Largo, FL
    Tom Sweet
    I started to notice that my front suspension has a bit of a squeak on bumpy roads.
    Has anyone had this problem?
    If so how did you fix it?
    TIA
  2. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Check sway bar bolts for tightening. Could be a bushing has bitten the dust too.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Spray WD-40 onto all joints/junctions, including bushings and sway bar bolts, but especially on the very top and bottom of the front springs as a temporary *test* to see if the noises go away.
  4. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You sure that's wise? Rubber and WD-40 don't really go well together, especially if you apply heat.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Unless the WD-40 is ignited, it's fine on rubber: http://www.wd40.com/Brands/wd40_faqs.html
  6. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    What sounded like a squeek in the front suspension of my 348 turned out to be coming from the front trunk latches, and it was fixed by spraying some WD-40 onto the latches.
