488 - Squeaky brakes after track day | FerrariChat
488 Squeaky brakes after track day
Discussion in '458 Italia/488/F8' started by amazingtrails, May 16, 2025.
  1. amazingtrails
    amazingtrails Karting
    Jan 4, 2025
    77
    I recently took my 2017 488 Spider to my first track day and ran it hard around the track for a couple hours. It handled amazing and everything went well. However, since that day my brakes have been squeaky - mostly when I'm slow braking into a stop. Could it be the brake pads are worn out? It was just serviced and certified in Dec when I purchased it. I wasn't planning to do the annual service until Nov / Dec. Thoughts?
  2. ferrariauto
    ferrariauto Rookie
    Jan 20, 2025
    2
    Tommy
    if you hose down the rotors and calipers the squeak might stop, it worked for me.
    3POINT8 likes this.
  3. 3POINT8
    3POINT8 F1 Veteran Rossa Subscribed Silver Subscribed
    Jan 23, 2014
    5,278
    probably dust or rocks in calipers. hose down and drive. it'll go away.
  4. Snewton94024
    Snewton94024 Formula Junior
    Apr 24, 2015
    566
    Silicon Valley
    Steve Newton
    Tracking for a couple of hours is quite a bit.
    Did you change the brake fluid before doing that or run it on the standard fluid? At Laguna Seca we are required to change out the brake fluid before tracking the car. My thought is to change out the brake fluid now and see if that helps.
  5. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,446
    Tampa FL
    it's pad build up on the rotors causing the pads to vibrate thus squeal/squeak. Stock pads can't handle the heat of track driving. Those pads are made for cold brakes on the street.
    Street driving will rub off build up over the next 500 miles. You should re-bed in the pads to the rotors. You probably did not do that before track driving and the pads transferred material to the rotor unevenly.
    But if you wash off rotors with soap and water and wipe with rubbing alcohol will help also remove pads and clean them up with sand paper on a flat surface helps.
    Next time use pagid rsc1 pads and properly bed them in. Track pads can with stand the heat of track driving and hold up better.
    I did all above on my 488 after a light 2 sessions of track driving on stock pads and it all helped, no guarantee but it helps . However after a while my 488 would start to squeak again a little . Interesting my F8 brakes are quiet and car hasn't tracked.
    BuyHighSellLow and Trev450 like this.
  6. amazingtrails
    Jan 4, 2025
    77
    Thanks for all the replies. I tried using a pressure washer to wash the brakes and calipers but they still squeak.
  7. amazingtrails
    Jan 4, 2025
    77
    How to I re-bed the pads to the rotors?
  8. amazingtrails
    Jan 4, 2025
    77
    I didn't change any brake fluid. It was a solid hour on the track driving really hard. I'm not about to do any maintenance work myself on a $250K ferrari :)
  9. emmholla
    emmholla Formula Junior
    Dec 15, 2018
    256
    Drive up to about 110mph then brake to about 30mph. The idea is to get some head into the pads so the uneveness will wear away. Also, after doing this 5-6x straight drive for a while to cool the brakes down. It should get better.
  10. amazingtrails
    Jan 4, 2025
    77
    I'll give that a try. I like driving over 100 mph :)
  11. amazingtrails
    Jan 4, 2025
    77
    I tried all of these suggestions (power washing brakes, rebedding pads, brake cleaner, etc) and nothing is fixing the squeaking issues. Mostly squeaking at low speeds. Brake pads look ok. Help!!
  12. Trev450
    Trev450 Formula Junior
    Mar 11, 2024
    617
    Trevor H
    I assume that these brakes have anti squeal shims similar to steel brakes, if so, then a smear of Mintex Cera Tec between the back of the pads and the shim could work.
  13. SAFE4NOW
    SAFE4NOW F1 Veteran Sponsor Owner
    Aug 25, 2004
    5,830
    Dallas Texas
    If you know you know
    I would suggest going to the shop of your choice, share with them what is going on, and let them take a look.
    They have the ability to remove the pads from the calipers, clean / remove build up in and around the pad / caliper / rotor area
    Then use acetone to clean up the rotors, apply brake paste to the pads
    reassembly and re-bed your brakes for you. If done correctly should take less than 5 hours for all 4
    Not guaranteed to last forever, but should help out till your next track day!
    ( I would be very surprised if you used up the brakes, you would have had to be trying really hard, and over driving the you know what out of them, which is always possible )
    Steve
  14. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
    Steve,
    I notice most 458/488/F8 brakes have no pad shims installed. When I bought new Brembo pads, they came with new shims and I used them. Is there a preference with or without?
