squeaky door panels on a 348 | FerrariChat
Discussion in 'Technical Q&A' started by traimpz348, Jul 17, 2005.
  1. traimpz348
    traimpz348 Formula 3
    Apr 13, 2004
    1,568
    Avon,CT
    Matthew
    Any remedy for a squeaky door panel? My feeling is it has been removed several times to fix a sticky door. Now it's kind of loose and squeaky. Should I replace the whole thing or is something else I can do?
  2. MDshore348
    MDshore348 Formula 3
    Dec 24, 2004
    2,460
    Maryland
    Darron
    my rocker panel / step plate on the pass side squeeked on an irregular surface, ie. entering driveway. where the panels overlapped i put a small bead of clear silicone between , let it cure then tightened down . it made a gasket separation of sorts. quiet ever since...
