Sqweel/churp when shifting at high RPM | FerrariChat
Discussion in '360/430' started by zsnnf, Jun 28, 2019.
  1. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    So my 2009 Scud makes a Sqweel/chirp when shifting at high RPM in F1-S. No it's not the tires. A mechanic told me this is normal (belts) but other Scud owners look at me like I'm crazy, they have never heard it.
    Help!
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    458s make a belt chirp when shifting at full throttle near redline. I have never heard a Scud do it, but it is most likely the same thing. How old is your drive belt? If more than 5 or 6 years old, I would replace it at the next service and see if it fixes the issue. Have your technician check the tension of the belt with a belt frequency meter to see if it is correct, if too low, you should replace the belt tensioner/pulley as well.
    It could be something else, noises are hard to locate, especially under the circumstances that you are having.
  3. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    thank you. The car is new to me so I don’t know belt age.
    Does anyone else hear this noise?
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    The belt has a date code printed on it. The first two digits are the year
    brookliner7 likes this.
