SSC Tuatara | Page 6 | FerrariChat
SSC Tuatara
Discussion in 'American Muscle' started by BJK, Feb 7, 2020.
  1. PaganiHuyara
    PaganiHuyara Rookie
    BANNED Silver Subscribed
    Aug 31, 2021
    45
    You believe that number?
  2. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
    #127 BJK, May 25, 2022
  3. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
    PaganiHuyara and ChipG like this.
  4. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
  5. ChipG
    ChipG Formula 3
    May 26, 2011
    1,764
    Santa Monica, CA
    Geez, when he slowed to 200mph it looked like you could get out of the car and walk LOL
    Thecadster likes this.
  6. Thecadster
    Thecadster F1 Veteran
    7,731
    That was incredible. Strong comeback from the…uh…problems they had before.
    Boomhauer likes this.
  7. Phil~
    Phil~ F1 Rookie
    3,937
    Potomac, Maryland
    Good show!
    tritone likes this.
  8. Scudmsl
    Scudmsl Formula Junior
    Aug 12, 2014
    856
    Incredible! Really nice job Larry!
  9. LMPDesigner
    LMPDesigner F1 Rookie
    3,212
    Atlanta Georgia
    That is a third spring setup. Allows you to do two things. Control the ride height of the ride height at speed and allows you to run softer springs on the corners.
    Wat it works is simple. In bump or droop the two susp rockers rotate the same way, same amount. So the drop links off those rockers move fwd/aft in parallel. SO at speed, under aero load both rockers move as teh suspension squats. That pushes or pulls (designs differ) on the third spring, causing it to compress. So now you have three springs resisting the car squating. Thru clever use of kinematics, rocker ratios, third spring initiation point the third spring can get very stiff in a very short amount of travel. By adjusting everything just right you can get the third spring to go very solid at a specific car ride height. So at that point in time the car stops squatting-hence you have a fixed ride height that maximizes the aero from the tunnels.
    Now in a corner the rockers rotate opposite to each other. So the drop links from the rockers to the third spring attach to what is called a T-bar. The T bar center is attached to the third spring, but can rotate freely. The T bar has two ears, one for each drop link. So when the car is in a turn, the T Bar rotates but does not translate (much), so the third spring is never compressed-or much. In squat the drop links are both pulling equally on the t Bar so it does not rotate, just translates.
    Also this allows each corner spring to be a lot softer, enhancing mechanical grip, especially in one wheel curbing.
    Been in use on race cars since early 90's. I designed one of the first systems for an Indycar when i was with Rahals. Now some low cost SCCA race cars have them.
    sainthoo and PaganiHuyara like this.
  10. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    Thank You very informative! And an beautifully designed engineering piece. It's artwork.
  11. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
    Oct. '22 (comparison of 200+ mph acceleration between SSC, Bugatti, Koenigsegg, and Hennessey)
  12. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    Incredible hypercar. I Love it!
  13. tuatara No.1
    tuatara No.1 Rookie
    Jul 16, 2022
    14
    BJK and Thecadster like this.
  14. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
    "tuatara No.1" ??? o_O ...... ok, explain :D ....... fan? owner? employee?
    tuatara No.1 likes this.
  15. tuatara No.1
    tuatara No.1 Rookie
    Jul 16, 2022
    14
    a fan
  16. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
  17. tuatara No.1
    tuatara No.1 Rookie
    Jul 16, 2022
    14
  18. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    The SSC Tuatara Striker was "unveiled" in 2021. They've had a Grey/Red/Black ones on their Social feeds for months. That's if the renders are accurate.
    They are irrelevant. They need more production of the high speed models to legitimize their claim as "World Champions".
    There is zero proof of any second model or any homologation paperwork files anywhere. EPA/Crash testing. The car has ZERO provenance and the only number plates ever seen on it are owned by SSC North America. Dealer plates.
    They currently the VBox Champions. Guinness World Records wouldn't touch that claim with a barge pole and the owner needs to stop trash talking other hypercar manufacturers who are WAY ahead in the curve.
  19. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    Do you want to show me where the catalytic converters are? You'll call the fully WORLD homologated crash tested EPA certified multi production model delivered Pininfarina Battista a "kit car?" LOL! I don't think so!
    Legitimately independently tested and verified? Did their clocks suddenly read 331MPH?
    Touch some grass.
  20. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    HOLY S! You think "maybe" it would take HALF A MILE to do 5MPH more?
  21. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,726
    CT
    how much time do you think it takes to cover 1/2 mile going 300mph? :rolleyes: .......... someone do the math please. (it's been too many years since I had to figure out "If a train left Chicago ........) :D
  22. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    I don't need to do anything? Racelogic and Jerod Shelby stated what the extra 5MPH would take to do and published it in the official 295MPH report. It wasn't HALF a bloody mile kid! But Thanks for stopping by.
  23. tuatara No.1
    tuatara No.1 Rookie
    Jul 16, 2022
    14
  24. PaganiHuyara
    PaganiHuyara Rookie
    Aug 31, 2021
    45
    That exhaust has nothing to do with SSC. It's Zanders "Z pipe" and his technology and his patented designs. Smh.
    And trust? No bloody chance. I'm in because of the designer. Put his name in the trash.
  25. tuatara No.1
    tuatara No.1 Rookie
    Jul 16, 2022
    14
    Isn't this exhaust installed on ssc tuatara striker? Koenigsegg regera uses Akrapovic exhaust, pagani uses amg engine, and the electrical system of Aston Martin Valkyria is provided by Rimac. Small manufacturers don't have enough money to manufacture all products, so they authorize other manufacturers to manufacture the products they want to achieve the best results, which is understandable. The record of 295mph is a fact. No matter how much you hate them, they are always moving forward.
