Staeger tool on Ferrari 348 belts | Page 2 | FerrariChat
Discussion in '348/355' started by dino206, Jul 15, 2017.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    140-145 hz I find as stated value in hz for the 348. Seeing if others can corroborate that.
    Sent using FerrariChat.com mobile app
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    I never seen a hz number for the 348. I looked and called a few folks over the years but nothing.
    It can be calculated with cog width, weight and a few other factors but try a few different ways of adjusting it and jot down the numbers
  3. uber2
    uber2 Rookie
    Jun 1, 2020
    15
    Sweden
    Kasra A.
    A few months back I measured my new belt with Staeger and then with frequency. The tension was given default by the tensioner. It corresponded well with Staeger and given value from service manual.
    The spring in tensioner was not replaced with a new one.
    I’m frequency I got ~145Hz on each side. +/- 3Hz.
    kiosky and SoCal1 like this.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #30 Ferrarium, May 25, 2022
    Excellent my man! Both Staeger and frequency. I heard 142hz so that was correct information. It was right, I set mine to 144. I used a new spring as well. Very very very useful post that has been asked for years, your the first to post both freq and Staeger after Staeger is set. Empirical evidence in other words. Much obliged!
    SPOM13, steved033 and SoCal1 like this.
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    This is one of the most useful posts I seen in years here for a 348 :)
  6. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,399
    Atlanta, GA
    Steve D.
    I have waited so long for this info...
    sjd
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #33 Ferrarium, May 25, 2022
    Nismodrifter said it was 142hz in my repair thread although he did not mentioned how he got that. I assume checking existing belt. Wanted to see if anyone did Staeger and then the frequency. I bumped the thread to confirm what he has said, sort of double entry book keeping. And looky here. Thanks Nismodrifter and uber2.
    I tried to find a non Porsche Staeger tool (apparently some difference in measurement there was a whole thread on it a while back) to do it myself but man, those are as rare.
  8. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    Hello
    Thanks very good information!
    I dit set mine around 140Hz also but to do so I had to remove some tension from the rest position of the tensioner since the spring (tried both new and used) was setting it around 150/160Hz IIRC if locked at the TDC After 2 turns.
    However the recommanded procedure (locking the tensioner at its highest position) was setting crazy tension (around 190Hz) and I thought it was a crazy tension.
    I am the only one to have to remove tension to get thèse 140Hz?
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  10. solana_sc
    solana_sc Rookie
    29
    SC, USA
    Walt Oliver
    As Steve said, this is a breakthrough--been hoping to get this info for such a long time! Thank you!
    steved033 likes this.
  11. SPOM13
    SPOM13 Karting
    79
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  13. SPOM13
    SPOM13 Karting
    79
  14. SPOM13
    SPOM13 Karting
    79
    Just to be clear. This is the reading I got after 4K miles. Belt is tight.
  15. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I got 150 ish hz on bank 1-4 and like 170 ish on 5-8 with #1 at tdc … manual says 140-160 on staeger (I thought those measured hz but that was internet info), and iit also has some poor English referring to measuring two points on the staeger.
    Anyway I might back it off a bit..?
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    staeger units are not hz they are it's own measure, but it does equate to hz which is 142 if I recall.
    The drive side is always tighter because it's the side that pulls the pulley the far side is trailing. I am not sure how you get the same measure on both sides with out backing off a few degrees when assembling.
    As far as tensioner follow the manual which sets the tensioner while turning engine over to it's maximum height, then re-check cams and repin if needed.
    Sent from my SM-G990U using FerrariChat.com mobile app
  17. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #43 luckydynes, Jun 25, 2023
    The manual says 140-160 staeger.. so is 142 hz for the lower or higher value? The valve springs on the second bank give the higher value.. I can hear it’s higher..
    sorry I read up above it’s for the lower value but since it’s not hz (even though only off by 2) I’m just curious what the high side is.. and maybe I’m not even supposed to worry about what the second bank is doing… there was some poor translation in there and I thought I’d read at one time to read both banks.
  18. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thanks ferrarium I’m just reading too much into the manuals poor translation.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    It's odd since the manual has procedure for belt install and setting that does not include stager.
    A separate section talks about the stager. But is sort of reads like that's for checking the belt after use not for install of a new belt.
    That's how I read it at least.
  20. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Right and they mention not being over 110%… like the belt gets tighter… or is it staeger values get higher as belt tensioner gets lower ;)
