Hi.. Have heard there are two sets of flexi brake pipes for the 328 ABS & Non ABS.... is this the case? Can anyone tell me if they know the following code for goodridge flexi lines on a 328? TFE0100-4P FERRARI 328GTB/GTS Thanks all!
Rod, I've replaced a few sets of flex brake lines on the various years of 328s... The front lines are all the same, the rears are not. On the ABS cars, the rear lines are longer. The Goodridge PN is: 27005 The number that you provided is listed by another vendor. As they do not specify a 328 w/ABS, hence likely it is the incorrect line. If you get into a bind and can't located them, I work with a customer manufacturer here in the States that makes all the lines I need, regardless of the application...in much higher quality materials than found on the Goodridge lines. David David
Michael, Interesting question. If you measure your rear lines, flange to flange...I can compare them to the 328 lines that I stock (of which, I know the application). David
Thanks David... Its a chap on ebay that is selling them as he no longer has his car and did not get round to fitting them.... I was just thinking for the buck it would be a worth while improvement to the car. Thanks for the info, I will measure the rear hose tomorrow and ask the seller to do the same? What sort of price are yours made up? I've replaced a few sets of flex brake lines on the various years of 328s... The front lines are all the same, the rears are not. On the ABS cars, the rear lines are longer. The Goodridge PN is: 27005 The number that you provided is listed by another vendor. As they do not specify a 328 w/ABS, hence likely it is the incorrect line. If you get into a bind and can't located them, I work with a customer manufacturer here in the States that makes all the lines I need, regardless of the application...in much higher quality materials than found on the Goodridge lines. David David[/QUOTE]
