430 - Stainless Steel Brake Lines | FerrariChat
430 Stainless Steel Brake Lines
Discussion in '360/430' started by Ray Smith, Sep 21, 2020.
  1. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Just ordered a set of stainless brake lines (4) with Kevlar casings and four liters of Motul 600RBF to be installed this weekend.
    Just a precaution. I've suffered spongy OEM brake lines and low boiling point fluid while racing at Barstow in July. I learned my lesson.
    Ray
  2. 24000rpm
    24000rpm F1 Rookie
    four liters? that much?
    i though 1 liter is overkill
    Flea7 and jcurry like this.
  3. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    I intend to completely flush the system as well as the ABS. The kit actually comes with 3 liters, not 4, my typo.
  4. sierra055
    sierra055 Formula Junior
    362
    Melbourne, AU
    Marshall
    I just did this myself and went through almost 2l giving a solid flush from each bleed point
    Ray Smith likes this.
  5. one4torque
    one4torque F1 Veteran
    5,720
    Houston
    One4torque
    I went thru this on my 360-
    I pulled the stock rubber brake lines and then waited weeks for my ss brake lines. This allowed the system to fully drain,
    so I had issues bleeding
    I took it to a shop to get firm brakes
    be sure you don’t leave the lines off for a long time
    best to have your lines ready to install
    or perhaps I’m just a brake bleeding fail :)
    Ray Smith and Manda racing like this.
  6. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    What information led you to leave the braking system open to the air?
  7. one4torque
    5,720
    Houston
    One4torque
    My ss brake lines were delayed in shipping. So I just placed rubber mech gloves over the lines and zip tied them. The rubber gloves expanded and filled w fluid. Was a mess. Not a deliberate act for sure.
  8. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Bummer...
    Did you bleed the ABS?
  9. one4torque
    5,720
    Houston
    One4torque
    I bled the system to the best of my abilities... but they were still not great. Had my buddies shop finish the job for proper firm pedal.
  10. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,270
    Bakersfield, Ca
    Mark
    You guys get the feeling doing it old school is best ? Someone pumping pedal.
  11. jcurry
    24,078
    In the past
    Jim
    ^^^^^^^ If I'm being very generous, or just take a nap while the long line is bleeding, I use a little over 500ml, i.e. one(1) bottle.
    As for ABS, I just make sure I activate it often to push fluid through the system.
  12. janmante
    janmante Karting
    176
    jan mante
    yes I need to get some lines what was your source ? Pls thx !
    we prefer Castrol SRF react racing fluid the best ( highest wet boiling pt ) in the world !
    Endless screwed us we bought some used pads for another car and sent them to them as they said they would make some high perf pads w/ them as samples then they reneged !
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    EBC in the uk do a set of 4
  14. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Replaced mine with goodridge SS lines....used 1.5 - 500 ml of Motul 600 RBF. Do yourself a favor and get a Motive bleeder.
    "racing" in oem brake lines and low temp fluid is not smart. LOL
    janmante likes this.
  15. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,322
    Maryland
    Mark
    I've done it both ways (not on f-cars specifically, but they're not really any different component-wise), pumping brakes and with a vacuum tool. Haven't really noticed a difference either way.
    Ray Smith and janmante like this.
  16. janmante
    janmante Karting
    176
    jan mante
    We do have a motive bleeder ! one might be advised to wrap big towel around it as Dan, ( Normal guy supercar ,) had the cap pop off as i recall, on one of his videos and it made quite a mess !
  17. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    what is SS part number and where did you order from?
  18. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    That's the guy who didn't know there were 2 bleed valve (nipples) on his brake calipers when changing his brake fluid. The cap on my bleeder has never popped off. Oh..btw..he set his F430 he was prepping to sell on fire...... brilliant!!!!
  19. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    For stoptech:
    950.03003 is for the front as the caliper has hard-line that goes into the clipped end.
    950.03501 is for the rear as the SS hose screws directly into the caliper.
  20. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,915
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    autowerks9 likes this.
  21. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    armedferret likes this.
  22. mathewr
    mathewr F1 Rookie
    Dec 7, 2011
    2,915
    Ferrari Wheel Guru
  23. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I have StopTech SS lines on my 360. There is an improvement in feel, although I changed the pads at the same time so it’s possible the pads (StopTech Sport) contributed.
  24. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
    We would be happy to offer our stainless brake lines to Fchat members for a special price $149 plus shipping, list is $179 for most models. We have been producing these for the last 8 years. All lines are bench tested prior to shipping. Added options for color or clear PVC coating to the stainless. A great option as it prevents road grime from discoloring the stainless strands
    David
  25. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    I got mine from Formula Dynamics. I think they are in Las Vegas, NV. Shipped fast.
    Ray
