STANCEPART AIRCUPS FOR F355 QUESTIONS | FerrariChat
Discussion in '348/355' started by olive, Aug 2, 2023.
  1. olive
    olive Karting
    Feb 2, 2006
    76
    Paris,France
    olivier C
    Hello,
    I'm in the process of ordering stanceparts air cups kit for the 355,I could never get used scraping the front bumper getting in and out of my parking, it hurts every time.
    After some research,the stancepart air cup system seemed to be the best option to resolve this.But reading through the forum today,I found a post from radback stating that the stancepart air cups wouldn't fit our OEM F355 Bilstein coilovers. Quite a disappointment, as I was about to order the tankless system with just the compressor. Contact at stance parts believes their air cup kit is compatible with our cars.I'm very confused now and would appreciate if radback and other members could confirm or not compatibility with OEM coilovers and if this is the case, what are the options to resolve the matter. different car of course,but I've seen a very successful fitting of stance parts air cup kit on a 458.
    Thanks in advance for all advice.
    Cheers from Paris.
    olivier
  2. radback
    radback Formula Junior
    706
    France
    I already replied to Olive in private, but if others are interested, Stanceparts cups won't fit as is because they are 111mm diameter and it is to close to the shock mount cage.
    They might fit after some grinding.
    And you also have to find a special top mount and fit narrow springs on existing suspension or use aftermarket coilovers with their cups...
  3. OCKlasse
    OCKlasse Formula Junior
    704
    Newport Beach, CA
    Brandon K
    KW HLS is the way to go :)
  4. radback
    706
    France
    KW HLS is A way to go. But not as good as aircups ;)
    PS: by the way did you follow the thread about the switch?
    You said your F50 lift swith is a 2 way momentary switch right?
    I found a seller who has a one way F50 lift switch !
