Start up after exhaust install | Page 2 | FerrariChat
Discussion in '348/355' started by Buzzl, Aug 16, 2018.
  1. Buzzl
    Buzzl Formula Junior
    Made a bonehead move. Was sitting in our den on the phone with my son and all of a sudden I said " I could have re-installed the MAF in upside down" and that is exactly what I did. I always admit a mistake no matter how stupid it is. I posted this hoping that someone else would benefit from my mistake. Car runs and sounds great. Thanks to the guys that kept pushing me along to check everything.
    SAFE4NOW and Qavion like this.
  2. Qavion
    Qavion F1 World Champ
    14,536
    Ian Riddell
    Good to hear... although I can't see how it would make any difference. Experts? It's a hot wire type sensor and looking at online pictures, the hot wire is exposed with the MAF installed either way.
    It took me a while to figure out what was what on your solenoid valve photo, but the plumbing seems ok, according to the Capristo website (assuming the solenoid ports are the same on the type you have).
    I would have assumed that the bypass valve position would have no detrimental effect on the idling (although some Capristo systems do weird things with airflow).
  3. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    So if I disconnect the battery or isolate switch to off your saying that all faults remain??. My car is a 96 OBDII car. I've tried this and if I disconnect my battery all fault codes are erased? Can you give more info on your reply I'm curious
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Not talking about faults. On a 2.7 car if you disconnect the battery when reconnected you have to start the car with all accessories turned off and let it idle at operating temperature for 10 minutes to allow the ECU to relearn the operating parameters. On a 5.2 car this is not required. See the below excerpts from the manual for a 2.7 and a 5.2model car. Notice there is no section on reacquiring engine parameters in the 5.2 model manual, and there is noting in manual about doing so if you read through it.
    Beetle and Dave rocks like this.
  5. Qavion
    14,536
    Ian Riddell
    It seems they forgot to remove the relearning procedure from my 5.2 owner's handbook :p (Page L7 in my Australian Spider handbook)
    I think this contradiction was brought up before, but I don't think it was resolved.
    Beetle likes this.
  6. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Ferrari, like the 2.7 diagnostic codes, always clear as mud. The excerpt I posted above is from a 98. I also have a 97 manual which is the same. All they say on L7, or any page in section L, regarding disconnecting the battery is that if the battery is disconnected for a long period of time it should be recharged.
    Now, there was a TB issued for the 360/575M about the OBD II drive cycle. Does it apply to the 355 OBD II cars too? It's more than just letting the car idle.
    It sound like what they are saying re the 360 is that they want it to establish the LT and ST fuel trim at idle (adaptive values) before starting to drive. But if you don't follow the procedure it should just take longer for all the monitors to reset. And from my experience with other cars, if you check the monitors after performing a drive cycle 1/2 the time there will still be a couple that are "ready".
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I've done the "relearn" on my 98 5.2 a few times before this was discussed and a few times I did not. Have not notice a difference.
    taz355 likes this.
  8. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Oops,
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Me three
    Once up to operating temps drop the hammer and next light it idles like a kitten.
    One thing i did notice is every major it idles way smother when new clean injectors are installed. It obviously gets worse over time but never enough to be considered bad.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    You folks ever just ever wonder "if" the constant relean process for cars with battery disconnected is an a tributing factor to the header, cat issues? Always running in relearn mode without proper input from sensors.
    Things that make you scratch your nutts and rekin :)
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Judging by the heat in the engine bay I would guess problem with the headers is more heat cycle related and poor headers.
    Buzzl likes this.
