start up engine dialogue says: "Service".. | FerrariChat
Discussion in '360/430' started by shubchs, Aug 16, 2019.
  1. shubchs
    shubchs Karting
    Aug 22, 2015
    87
    Saint Paul MN
    Steve
    On start up a engine dialogue indicator says "service". I last had a full service done just 18 months ago (oil, breaks fluid in all areas). what could this check engine light mean? It does not go out when I drive, and the car (F430 Spider) drives faultlessly.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    ... Service is typically done annually regardless of miles. This isn't a Toyota. [emoji12]
    AClark likes this.
  3. tazandjan
    39,170
    Trev- I am basically of the opinion that any car needs an annual oil change, especially Ferraris.
    Steve- Have her serviced and your tech can turn off the service lamp.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    There is no service reminder system in an F430. You have to be more clear about what other lights are coming on with your "service" warning. Read your owners manual to see what the warning lights look like.
  5. f355spider
    f355spider F1 World Champ
    18,044
    Why especially a Ferrari? Because of the value versus risk? It is an interesting subject about annual oil changes with vehicles that often see very little use. Here is what was said by the folks at Blackstone Laboratories (oil analysis) on the subject of annual oil changes for cars that may only see a few hundred miles a year. For context, start listening at around 9:55 I don't discount that an annual service can still be worthwhile, to get the car on a lift, and inspect for leaks and other possible issues. Perform a brake fluid change, etc. But the habit of annual oil changes may not be absolutely necessary under low mileage use.
    mwstewart likes this.
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    I completely agree with the above.
  7. tazandjan
    39,170
    My opinion remains unfazed.
  8. RedNeck
    RedNeck F1 World Champ
    12,307
    The CSA
    Me
    Trev, you really need to start working on your remote, ESP based OBD code reader for posts like these that keep popping up.
    Seriously guys, get a code reader. Nobody on a message forum can help you with a code or a warning light if we don't know what it is.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    There is no Service reminder indicator message on a 430. The only thing that says "Service" on the dash is when there is a problem with the TPMS system. The dash will display a U-shaped icon (the cross-section of a tire) with "Service" below it. RTFM!
    f355spider likes this.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Steve (the OP) stopped over and yes, it was a TPMS fault.
  11. FantasiaForest
    Feb 22, 2019
    32
    Jacksonville Fl
    Joe C Rudkin Ii
    Im a fairly new 360 owner. What is the best code reader under $1000? As I understood it the code readers can only read the Primary ECU and are unable to read the second one and the TCU? Is there any that will read all of them?
  12. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,225
    Shorewood, MN
    Kevin
    Get yourself any old OBD II connection device, and then OBD Fusion app. This allows you to access both ECUs.
    The Launch x431 will work for the TCU on later version 360 TCU (at or beyond 191701 I believe) as well as the CS TCU (196986)
    Kevin
    FantasiaForest likes this.
  13. RedNeck
    12,307
    The CSA
    Me
    I use the Foxwell, they have the NT510 and the NT250, both can come preloaded with Ferrari specific codes, they will not read the TCU, ABS, or Airbag system. We have a guy here, @360trev who is working on an affordable system that will do all..
