starter motor cable | FerrariChat
starter motor cable
Discussion in '206/246' started by snowsports1, Oct 18, 2013.
  1. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    I need to buy a starter motor cable, can someone help with size, colour and length please, mine is missing so I don't have anything to copy.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,230
    Norfolk - UK
    Tony
    Battery Cable - Flexible
    Black 170a is Ok, 300amp is even better.
    Get the flexible cable as it is better to turn onto the starter and battery
    5m is ample.
  3. snowsports1
    Jan 31, 2013
    918
    Brian
    thanks tony, I see they do the tinned cable in 35mm2 which splits the difference..
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,230
    Norfolk - UK
    Tony
    even better, it also depends on the starter. The original draws huge amounts of current, the gear reduction unit is much more efficient. Don't forgot then terminal tags.
    While you are at it, check the charging circuit cable too, that is always prone to terminal corrosion and high resistances. This then melts the insulation which then shorts out, which result in a fire. If it doesn't do this then it fries the battery because it is overcharging all the time.
