Starter motor on 550 | FerrariChat
Discussion in '456/550/575' started by Michael Sundler, Aug 6, 2022.
  1. Michael Sundler
    Sep 22, 2018
    7
    Michael Sundler
    Wonder if anybody can help with my 550 starter problem. On inserting the ignition key and depressing the immobilizer button on the fob, all dashboard lights come on as appropriate, followed by the green “OK” message. However further turning of the key to the start position fails to cause the starter motor to respond. Normally I would assume this to be a problem with the starter relay, but before pulling things apart I wonder if anybody could confirm this diagnosis - and give me a clue how to find and access the motor and it’s relay! Thanks for any help!
  2. tazandjan
    39,175
    Cheapest thing is to change out your fob battery or try another fob. On the 550, if the immobilizer is armed, she will not turn over. On the 575M, she will turn over, but will not start.
  3. Michael Sundler
    Sep 22, 2018
    7
    Michael Sundler
    Thank you. I have tried the other fobs including the red one, but no difference.
  4. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    I would make sure the fob batteries are fresh, and how about the car battery, how old? Even some seemingly fully charged older batteries won’t make a Maranello happy. Then there is the alarm battery. I would trouble shoot these areas long before digging into a starter unless you are able to diagnose the electrical system properly.
    Bill
    FL
  5. fatbillybob
    Aug 10, 2002
    29,017
    socal
    Strangely I have changed batteries and still had a FOB failure. Then I used my PIN to start and get home. Once home I'm jiggling the FOB and now it works! Yes I bent the pins in to get good contact. Sometimes your Ferrari hates you.
    To the OP next step put a stick or better a metal pipe on the starter motor case and wack it with a hammer. Then try key...sometimes you get lucky. Listen carefully, a click from passenger footwell is a relay and click in engine bay with no motor turning is bad solinoid. No click in engine bay can be bad soliniod bad starter, wiring etc...
    Qavion likes this.
  6. Qavion
    Qavion F1 World Champ
    14,304
    Ian Riddell
    The relay is found near the right hand bank Motronic ECU which is behind the carpet just forward of the door pillar.
    "X" marks the spot
    The above photo shows a diagnostic scanner plugged in the ECU's diagnostic port.
    Here's a photo of the (Bosch) starter relay
    I don't think relays fail all that often, but it's easy to swap with another relay with the same part number (Bosch 0 332 019 103).
    F456M and 308 GTB like this.
  7. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    That's one way to fix a dead spot in the starter motor. Another way is to put the car in first gear and push the car forward and back a couple of times and then try starting the car.
    Qavion likes this.
  8. Michael Sundler
    Sep 22, 2018
    7
    Michael Sundler
    Gentlemen, I am so grateful to you all for your helpful comments and suggestions. Clearly, the whole system is very sensitive to various voltages, I made sure the car battery was fully charged, changed the fob battery and it now APPEARS to be resolved. Again my thanks for steering me away from the starter motor!
    Hawkeye and Qavion like this.
  9. Michael Sundler
    Sep 22, 2018
    7
    Michael Sundler
    I think I have finally resolved this issue and, as many of you suggested, it seems to be the fob! One learning for me is that even though the red LED on the fob illuminates when the button is depressed, it doesn’t mean that the fob is emitting any or sufficient power to disengage the immobilizer. Thank you all again for your invaluable guidance.
    Ferrari55whoa and Qavion like this.
  10. tazandjan
    39,175
    I got tired of changing the batteries every 6-12 months and Mark at ferrarifobs.com sold me a set of three fobs powered by lithium watch batteries. He also has combination fobs like the F430 that have key and fob combined for our earlier Ferraris.
    F456M likes this.
