Starter motor won't engage... help with steps to diagnose | FerrariChat
Discussion in '308/328' started by Andy 308GTB, Sep 10, 2018.
  1. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Although the problem is with my 308, it is really a general car question. I'll post it up here because you tend to be a receptive crowd...
    Starter Motor - rebuilt 2 years ago. No previous issues.
    Battery - Bosch battery less than 2 years old. It was charged yesterday, output = 12.85 volts.
    24 hours later, output = 12.85 volts
    Terminals are tight with zero corrosion.
    Here are the steps...
    1. Battery isolator switched on
    2. Alarm fob inserted
    3. Alarm bleeps - indicating that the alarm/immobilizer has been disabled
    4. Turn on ignition
    5. At this point the fuel pump whirrs into life, the windows can be operated & the lights can be switched on. This suggests to me all is well
    6. Turn the key to the next position to start the car.
    7. I get the rattling/jangling sound that I would normally associate with a weak battery that hasn't got enough oomph to engage the starter motor. Sometimes it will continue until I release the key but once or twice it has stopped of its own accord and I have had to switch the battery isolator off and back on.
    My guess is that the starter motor cannot engage or is somehow jammed and needs to be released?
    Any opinions or suggestions on how best to proceed would be appreciated.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Erm... Let's start with: what is a "battery isolator"? Not familiar with that term.
  3. absostone
    absostone F1 World Champ
    10,020
    Maybe a cut off switch?
  4. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Try using jumper cables to another battery. Also try putting a thick cable directly to the starter if you have one and check the earth straps at battery/frame and frame to engine. Sounds like a bad battery or bad connection.
  5. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    A battery isolator, isolates the battery [emoji3]
    It means that the battery does not get drained by the clock etc. if the car isn't driven on a regular basis.
    Mine operates using a big, red, plastic key that you often see on racing cars.
    Sent from my ONEPLUS A3003 using Tapatalk
  6. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Thanks.
    Swapping the battery over will eliminate any doubts over the condition of the battery - and I will do this. But by all accounts, if a battery maintains a voltage in excess of 12.65 volts it is in good health?
    If that doesn't work, I will get the old girl up in the air and check the starter motor wiring and the earth straps.
  7. absostone
    10,020
    Solenoid? Relay?
  8. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Wiring the starter motor directly to the battery with a thick cable is a good idea but will be real tricky to achieve.
    I've bypassed the wiring loom in this way when I've had ignition woes but it was more accessible.
  9. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    This is my other line of thought. How do you tell if a relay has packed up,?
    The solenoid is what kicks in the actual start motor gear to spin the engine. Hitting the starter motor with a hammer can, apparently, free up a stuck solenoid. But I have read that this isn't a good idea too...
  10. absostone
    10,020
    Not sure. You’ll need to go down the line one at a time. Do you have a lift?
    Starter is not hard to remove if u do. Maybe it’s time for a starter rebuild and new solenoid anyways. It’s your cars way of saying it wants to play
  11. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    You said it's making a rattling sound; different than the normal tired wrrr wrrr cranking sound of the engine?
    If YES, (different noise), then have a look at the starter drive components and where it's connecting. The problem may be mechanical.
    Saabguy likes this.
  12. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    I think I will end up poking around the starter motor itself.
    It is not a case of the engine turning but not firing. The starter motor is not engaging, the engine is not being turned. The rattling sound, I presume is the solenoid failing to engage the starter motor gears.
    Ideally, I'd like to know how to test the relay - although it may be simpler to replace it. Superformance only list a single relay - are the relays on the fuse board all the same. Surely not?
    The starter motor was rebuilt 2 years ago, I was thinking maybe it just could have jammed and there was simple way to 'unjam' it? i.e. hitting the solenoid with a hammer...
    When I did a load of work in that area 2 years ago, I cleaned and checked the earth straps and their connections. I will look at them again once I get the car on jacks.
  13. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,130
    The starter motor relay is mounted on or in the starter motor itself. It's not in the fuse board.
    TBH it sounds like a weak battery; I'd change that before messing around with the starter motor, especially as it's relatively newly rebuilt.
  14. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    You're not wrong.
    The battery is a Bosch less than 18 months old, and it appears to be holding charge OK - but it has to be my first port of call.
  15. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    The solenoid is closing, then the voltage drops and the solenoid opens, then the voltage picks up so the solenoid closes,… click, click, click. You have a bad battery or bad connections. As I said, try another battery and check all of your connections including straps.
    If you can hear something turning (but not the engine) perhaps with a grinding noise then it is your starter clutch/Bendix
    johnk... and Patrick Dixon like this.
  16. conan
    conan Formula Junior
    Nov 13, 2011
    389
    Not necessarily. The battery may report a decent voltage when not loaded, but when loaded with a starter motor, the voltage may drop too low due to a too high battery "internal impedance". In such a case, the battery just don't deliver enough current to the starter. The relay clicking is a perfect example of a bad battery or a bad connection somewhere.
    Saabguy and Patrick Dixon like this.
  17. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,190
    Kingsport, TN
    Lawrence A. Coppari
    Check voltage drops when you attempt to start the engine. I just went through a single click only problem with my 328. The contributors here helped a lot. Here is the link. My starter has now worked properly 22 times in a row so I can assume the problem is solved.
    https://www.ferrarichat.com/forum/threads/wires-on-starter.583379/
  18. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    I'd opine that it's a battery or cable/connection issue. If the solenoid is chattering, it indicates insufficient current available to engage the starter. IF there is sufficient current, the solenoid would engage and spin the starter. If the starter was locked up, the solenoid would engage correctly but the starter would not spin. You would hear a single "CLACK" as the solenoid engaged and then (usually) a noticeable hum from the starter motor coils. If that occurs, release the key immediately to avoid damaging the coils/wiring though the related start switch/solenoid fuse should blow pretty quickly and also eliminate any possible damage..
    thorn likes this.
  19. Hank Rose
    Hank Rose Rookie
    Mar 8, 2012
    29
    There is a large cable that goes directly to the starter motor. Check this for a tight connection. It may be a good idea to clean the connection. Good luck
  20. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Hi Andy,
    how much is the battery voltage while you turn the key? A defective battery can show healthy voltage without load, but collapses when you turn the key.
    The noises you describe are exactly the same like on my car each time the battery was tired. The 308 seems not to make the classical noises we know from every other car. Even a dying batterie produces drama music :)
    Best from Germany
    Martin
    Crowndog likes this.
  21. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Thanks everyone for your help. It was a weak battery. A virtual pint to everyone who guessed this.
    I'm a little sheepish, as in hindsight it may have been obvious but I had such faith in the battery - it's a Bosch and only 18 months old.
    In 20 years of ownership, this is only the cars 3rd battery, it appears to look after them (or more likely the fact that I have an isolator switch).
    I had probably drained it a bit when I was fixing the passenger side electric window the other week - but I had taken the car for a run afterwards and all was well.
    This evening, I swapped the battery for the one from my daily driver and it started. I now have the Bosch battery back on charge, I'll give it one opportunity to redeem itself.
    Just for clarity - and putting it into terms that I can understand...
    The fact that the battery shows and retains in excess of 12.65 volts, merely shows that it's been charged to its capacity?
    That capacity may be very low if the battery is defective or has been damaged - and this poor capacity is only exposed under load?
  22. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    it's quite possible that a fully charged battery is incapable of pushing through the amount of current needed by the starter system. With the proper equipment this only takes a few seconds to diagnose.
  23. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    No. But a charger with an amp meter would help monitoring the charging process. If the amps go close to zero it has approximately reached its capacity.
    I once had a battery on a daily driver, which failed after 14 months. Due to german warranty law they had to replace it for free. I just wonder, whether this isn't EU-law. Since your Brexit isn't completed yet :) it may be, that the same warranty (24 months) applies to the Uk as well.
    Best from Germany
    Martin
  24. Patrick Dixon
    Mar 27, 2012
    1,130
    I've found that batteries that are allowed to discharge don't seem to last very long these days and I've had a few that have failed 'prematurely'. Anyway Bosch is just a label; things are all made for various labels these days and there are plenty of fakes about.
  25. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    It is also possible that the battery was OK but the process of switching them cleaned/corrected a poor connection at the batt terminals.
    FWIW, when you check batt voltage, check it in two spots - with the meter probes on the battery posts themselves, and then again with the meter probes on the cable terminals. This will often show up a faulty connection since there should be absolutely no voltage difference in the two measurements. But, as noted, you can have proper voltage but no hi-amperage capability with a faulty battery, cable, or connection. IOW, everything in the car will work. normally..except the starter. ;)
