starter work fine on bench, does not work in car? | FerrariChat
Discussion in 'Technical Q&A' started by yelcab, Jul 13, 2025 at 2:49 PM.
  1. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    I have a 355 starter that ...:
    1) tested just fine on the bench: connects 12V to big terminal, Ground to body of starter, jump 12 volts to small terminal (Ignition) and bendix gear jumps out, and starter spins.
    2) Install starter in the car, connect 12V to large terminal, ground to body of engine at the starter, connect 12V to the small terminal: Starter motor does spin but the engine does not spin because the bendix gear does not engage with ring gear. So, I cannot perform a compression test.
    Why?
  2. Willl
    Willl Karting
    Oct 8, 2022
    150
    Vancouver, WA
    Will
    Bad ground/contact
    Not enough juice in the battery to drive the bendix gear
    Bad alignment/blockage
    Bad bendix gear/solenoid
  3. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    28,947
    socal
    Yeah...I agree. Jump the starter directly with known good battery power to make sure the problem isn't the car electronics. Make sure you in neutral and chocked.
    Sometimes bad solenoid the pecker will pop out but have no chutzpah!
    Qavion likes this.
  4. yelcab
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    It's the clutch in the Bendix gear. New starter is needed. It cannot be rebuilt.
  5. Phelips
    Phelips Karting
    May 30, 2025
    60
    Russel Phelips Brown
    Your starter bench-tests fine but won’t engage the flywheel in the car most likely due to voltage drop under load or a weak solenoid signal. Check battery health, clean all connections (especially the small trigger wire), and verify proper ground. If voltage stays strong but it still won’t engage, the starter might need a shim or the solenoid is failing under real-world load. A compression test requires solid cranking, so fix this first.
