Starting a 360 Spider | FerrariChat
Discussion in '360/430' started by dwilliams, Aug 26, 2013.
  1. dwilliams
    dwilliams Karting
    Jan 20, 2005
    54
    Altadena, CA
    Dennis E. Williams
    My friend has a 2003 Ferrari 360 Spider with a paddle shifter. He has since passed away and his son asked me how to start it as it hasn't been driven in over a year. The following details have been relayed to me by his son.
    1. The car has been on a trickle charger-It has a full charge as evident by bright headlights and electronics
    2. I have exposed the battery at the passenger footrest and all seems to be in order
    3. Both times trying to start it I closed the door to ensure that the alarm is disarmed and turned the key. All gauges move, but all I hear is a thug and nothing turns over. It displays a “N” on the instrument panel. I am assuming that is for neutral.
    4. I only have one black key and cannot locate the red key
    5. I have read numerous blogs and most mention the possibility of the red key being the
    “Immobilizer”
    Any help would be appreciated.
  2. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    You are pressing the fob button and hearing two beeps first BEFORE trying to start the car correct? Pressing the fob button (inside or outside) the car is necessary to disarm the immobilizer, just to be clear. Also once you hear the two beeps you have a minute or two to start the car before you have to do the "two beep" procedure again....PS Don't worry about the red fob for now.
  3. Red 27
    Red 27 Formula 3
    Feb 2, 2008
    1,002
    San Diego, Ca
    Dave
    Not sure about the 360 but on the 430 the battery tender has to be disconnected for the car to start.
  4. ttforcefed
    ttforcefed F1 World Champ Rossa Subscribed
    Aug 22, 2002
    19,255
    yep 612 and FF too
  5. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    FWIW My 360 starts no problem with tender connected.....still think it has to do with incorrect operation of fob/disabling imbolizier...see above...that's where I would start.....
  6. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,159
    Your 360 does not have a factory CTEK with factory connectors like the late F430s, 612s, and 599s. Those do disable the ignition, but no factor with a 360, unless it came with a rare factory Zivan, and probably not then.
    Odds are the problem is not using the fob correctly, as stated. The key has nothing to do with the immobilizer, only the fob or the PIN code can disarm the immobilizer. Once disarmed with the fob, it takes 120 seconds for the immobilizer to rearm itself if no start attempt is made.
  7. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    Your procedure reads incomplete / incorrect - apologies for any error I now make
    You need one key and one fob - from a locked car plip the fob - a little light will wink on the fob and the car unlock - get in
    Put the key in the ignition and check the little red LED to your right on the centre dash - if it is blinking plip the fob again until it stops
    Ignition on - pull back on both paddles to get/check 'N' (neutral) - do not start the car until you see 'check ok' in front of you - start the car
    Let it idle a while - if you want to go in gear you need to press the brake pedal hard
    This is covered on page 3.5 of the manual (approx)
    Let us know any part that does not make sense or that does not work
  8. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    I think your battery is shot, it may have been on a trickle and may show full voltage but you said nothing turns over. Even IF you are not disabling the immobilizer the engine will turn over, it just wont start but it will turn over. So the fact the engine is not turning over implies to me a bad battery or bad connections, if it sat for a year, there could be corrision on the terminals and you are not getting any amps to the starter.
    And yes N is for neutral, you can either pull back both paddles to get into neutral or let the car do it for you as you turn the engine over. The 360 will start with the door open.
  9. Jeffg11
    Jeffg11 Formula Junior Owner Silver Subscribed
    May 31, 2004
    565
    Michigan
    Jeff Grabowski
    Are you pressing on the brake pedal when you turn the key? Make sure you press hard if the car has been sitting.
  10. ttforcefed
    Aug 22, 2002
    19,255
    dont the trunk and hoods beed to be closed also? i vaguely remember a buddy driving my 360 spider and some how cldnt start the car because he had by mistake opened the hood or trunk
  11. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    OP...Any luck??
  12. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    open and close the hoods.
  13. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    the 360 will start with the front hood and engine compartment open, it will give you a warning on the dash and happily start. It will NOT go into gear however with them open.
    I say again, check the battery, you are not getting enough juice to the starter.
  14. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    My 360 wont turn over at all unless you bleep the immobilizer...just FYI.
  15. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    mine will turn over...and turn over and turn ...until I either start dialing AAA or remember to disable it. In my defense I only got to the point of looking up AAA's number once on the first day of ownership. Since then, its just oh crap forgot yet again when it turns over and does not start.
  16. ttforcefed
    Aug 22, 2002
    19,255
    my 360 CS does that but its the alarm cut off switch. you need to arm and disarm the car to get the car started....really annoying
  17. ttforcefed
    Aug 22, 2002
    19,255
    thats right, i stand corrected.
  18. mello
    mello F1 Veteran Silver Subscribed
    Jul 12, 2013
    5,485
    CA Bay Area
    Steve
    Check the fuel supply interruption inertia switch. It's located on the driver side lower left foot well. Remove the cover and press the button on the switch. Turn the ignition switch to II position and wait a few seconds and then start up the engine.
  19. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    No word from OP if any of these suggestions worked??.....
    At least I have a list of trouble shooting tips now....Thanks, LOL!!
  20. dwilliams
    dwilliams Karting
    Jan 20, 2005
    54
    Altadena, CA
    Dennis E. Williams
    Thanks for all of your help. I passed on the suggestions and will let you know how it turns out
  21. mello
    Jul 12, 2013
    5,485
    CA Bay Area
    Steve
    i'm going to throw out another suggestion just for good luck. If the battery is not up to snuff to crank the engine at a sufficient RPM, the ECUs will cut off the injectors to prevent the engine from flooding.
