starting and warming up | FerrariChat
Discussion in '360/430' started by fabo, Feb 18, 2014.
  1. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    I was wondering...
    When I don't have time to drive my 360 I usually start her up and warm it up in the garage for a few minutes...maybe a few times a week to keep the battery charged
    Is it ok to do this or is it not good for the engine
    I know I need to get a battery tender...
  2. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Definitely not good for the engine; by letting it run for a couple of minutes all you're doing is allowing condensation to form within the engine. It's also unlikely that you're generating enough of a charge to compensate for the juice that was required to start it in the first place.
    IMHO, the best way to warm-up an engine is by driving her gently until everything gets up to temp.
    Do get yourself a battery tender.
  3. tazandjan
    39,170
    #3 tazandjan, Feb 18, 2014
    Joe- As long as you let the temperatures come up, it will not hurt her at all. Let the oil temperature get up to about 160 F or a little below and she will be fine. But picking up a battery maintainer is a good idea, something like the CTEK that came standard with later Ferraris, but with alligator clips. The non-Ferrari branded ones are inexpensive.
  4. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I'd be inclined to agree. It takes a good length of driving time to get everything up to full operating. I feel it's better not to start and idle like that.
  5. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    thanks guys
  6. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #6 English Rebel, Feb 19, 2014
  7. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I have the greatest of respect for you Terry, but cannot agree with this. The OP says he likes to let it run for a few minutes a few times a week. Getting the oil temp up to 160 degrees a few times a week on idle isn't, IMHO, the best way of treating any engine.
  8. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    I agree, I firmly believe (but my wife says I am often wrong) that you should never just start a car. Let it sit, or take it for a drive and get it properly hot.
  9. vrsurgeon
    vrsurgeon F1 World Champ
    16,528
    Charleston, SC
    Curt
    But will it HURT the engine? I don't think so. It might not be ideal.. but I don't htink you're going to actually hurt the engine if it idles until its warm.
    Think about it. The oil is going to recirculate around the engine in either case. Provided the oil pressure isn't bottoming out, running at 1200RPM versus 3000RPM is immaterial. If you drive it and lug the engine.. THAT would hurt it.
  10. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    When the engine just idles, the gas in the engine doesn't burn completely. The unburned fuel mixed with the oil inside the engine will cause the oil to lose its functions. Besides the motor, just idling can hurt your catalyst converters as well. These cars create a lot of water vapor in the exhaust system. The water usually just sits in the catalysts and can cause corrosion. If you're spending the time to idle, you might as well take it for a 15-20 mins spin to bring the motor, transmission and exhaust system up to full operating temp to burn off the moistures.
  11. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Yeah, okay, if we're having academic arguments, but what's the point? You'd let a >$100K car idle just to charge the battery, and you'd do it several times a week? It doesn't make any sense at all. If you let everything come up to temp I guess there might not be any damage to the engine, but I maintain that it's a nonsensical approach just to charge a battery.
    BTW, does anybody have a handle on how long the car needs to idle for in order for the oil to come up to normal operating temps? I bet it's quite a long time.
  12. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    Yes, it can hurt it, especially an aluminum engine with Ti rods. The combustion byproducts when cold have a lot of acid in them. This contaminates the oil and unless you get the oil hot enough to burn it off, it can pit the aluminum and Ti. You have to make sure the oil temp gets hot enough.
    You can also cause a lot of carbon buildup just letting the engine sit and idle which can damage the engine if the buildup gets to be enough. Not as big an issue on a non DI engine as it would be on a DI engine (like the cali, FF, F12, 458).
  13. vrsurgeon
    16,528
    Charleston, SC
    Curt
    And heating from an idle versus the slow rise from a careful drive? I doubt it. Oil temp on a 360 comes about slow enough as it is and is recirculating throughtout the engine via a pump either way. You're not going to rev the engine above 4k anyway until the engine is warm anyway. Carbon buildup... also like to see how it differs under 3k RPM warmup versus idle at 1800. I'll wager less than 10-15% variance unless someone provides numbers.
    Don't get me wrong.. none of us do it.. I just don't see how its bad logically. I'm not saying its right. I just don't understand how its any worse than a slow drive. Agreed on DFI vs. Non-DFI.
  14. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    That's the thing, just letting it sit and idle you never rev it up and get it hot. The op sounds like he's just letting it sit and idle once a week then shutting it off once hot to maintain the battery. That's not good for the engine imo for the above reasons. Letting it sit and idle to warm up and then taking it for a drive, probably not a big deal as long as you do drive it a decent distance (ie more than just a 5 minute jaunt around the block), but driving gently definitely warms it up faster and warms up the rest of the drivetrain along with the engine.
  15. C Alexander
    C Alexander Karting
    May 9, 2013
    190
    NY
    Mr. H
    For the guys with the CTEKs or other types of batt. tenders, what function do you normally leave it in?
    I know there are "normal", "quick charge", "trickle", and so on...
  16. tazandjan
    39,170
    Warming up a car does not mean you have to just let it idle. Running her up to 3000 rpm occasionally while she is warming is not an issue. The real trick to doing a static warm-up is getting the oil temperature up high enough to burn off anything generated in the oil through the combustion process.
    He asked if it hurt anything, and the answer is no if she is warmed thoroughly. It still makes much more sense to use a battery maintainer, of course. Mine gets driven enough that she has not been on the CTEK in over 4 years, but she has very little drain when sitting.
  17. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    #17 fabo, Feb 19, 2014
    I was looking around yesterday and I found this adaptor at the back of my passenger side seat...I presume this is a battery charger output?
    Has anyone seen this type of adaptor and can advise what type of charger I need to get?
    BTW the car is an import from England
  18. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    #18 RedTaxi, Feb 19, 2014
    Yes I wired in the same thing to my 360. You just need the matching plug to suit attached to a charger/tender and you should be good to go.
    It should be wired to the main positive terminal and to the main earth on the chassis. Easy to see with the floor panel behind the seat removed.
    I trickle mine overnight with a cheap 2 amp charger if it sits for more than a week.
  19. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    I say start the car and drive it. Don't let it idle. I have always believed extended idling is bad for a petrol engine. Oil temp comes up slowly even when driving. I imagine it would take forever just idling.
  20. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    Anyone know what type of charger I need?
  21. Caeruleus11
    Caeruleus11 F1 World Champ
    11,620
    I would add that in addition to the engine, its important to actually move the car every now and then, other wise things like the differential gears just stay ½ bathed in oil.
    My opinion is if you cant move the car due to weather or some other reason, you are better off not running it and keeping it on the tender.
  22. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Agree. Put a tender on the car and don't start it unless your gonna use it. If you want to avoid flat spots on the tires just roll her back by releasing the e brake and place in neutral
    R
  23. fabo
    fabo Formula Junior
    Dec 14, 2013
    552
    Fabo
    #23 fabo, Feb 19, 2014
    looking for a tender now....
  24. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Just buy a charger that comes with a pig-lead (many do or offer as an accessory) and replace the existing one with the new. More simple than trying to reverse-purchase what might not even be a good charger.
