Starting Electric | FerrariChat
Starting Electric
Discussion in '296' started by Puro, Mar 18, 2025.
  1. Puro
    Puro Karting
    Sep 15, 2022
    244
    Can you start/depart in electric mode, or does the motor always have to fire to warm up?
  2. mkraft3003
    mkraft3003 Formula 3
    2,376
    Tampa, Fl
    Can start and drive away in electric. Engine doesn't fire up until you select the mode.
    Dino_Argento likes this.
  3. Puro
    Puro Karting
    Sep 15, 2022
    244
    That doesn’t harm the engine kicking in cold?
  4. Caeruleus11
    Caeruleus11 F1 World Champ
    11,485
    No, just take it easy with the RPMs while warming up, like normal.
  5. Puro
    Puro Karting
    Sep 15, 2022
    244
    Good deal, and why does it have to plugged in if the engine regenerates/charges the battery while driving?
  6. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,223
    not to poach the tread but what type of plug in do i need to charge it? getting gts soon and need to know what to charger to put in my garage
    of2worlds likes this.
  7. Caeruleus11
    11,485
    One would think you shouldn’t need to plug it in but the battery for the hybrid seems to be the only one and it’s needed to run all the computers/ systems. The owners manual designates how often it needs to be plugged in. I forget what it says but I plug it in after every drive, because sometimes life gets ahead of me and I forget to come back and plug it in.
    The plug appears to be the ev standard style, but Im not sure about the different standards (theres the Tesla one and the other EV plug, I think they call it CSS, and I think the 296 uses this style.
    Personally, I think all this EV focus is a mistake. Ferrari should be about the engine first and foremost.
    3POINT8 and of2worlds like this.
  8. KL runner
    KL runner Formula Junior
    Jul 25, 2023
    679
    Not in US
    You need a regular plug , no special charger. When I asked the dealer he said leave it plugged in as the charger kicks in and out as needed. If I return from a drive with 50% charge left it takes a little under 2 hrs to charge fully then the lights on the charger go from two blue flashing to one.
    I hope this helps
    jm2, of2worlds, 3POINT8 and 2 others like this.
  9. Potentialshock
    Jan 7, 2024
    45
    J
    I use my tesla cable to charge my 296. Always arrive home on zero electric as I like to be in ev in traffic and charging to full is ~6.7kwh and takes 2 hours.
    I start and drive it in ev, then when close to city limits start the engine.
    Caeruleus11 likes this.
  10. Caeruleus11
    11,485
    Great use cases.
    Apologies for the confusion, I thought you meant the plug on the car itself. The included Ferrari tender/charger uses a standard wall outlet plug, you dont need anything special. However, they say you have to plug it directly into the wall, no extension cords, etc.
    KL runner likes this.
  11. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,223
    yes perfect thanks!
  12. PieGre
    PieGre Karting
    Jan 9, 2019
    147
    Luxembourg
    PG
    This depends on many things, like the temperature ... mine does not fire up in E-mode anymore after the 20.000 kms service ... there's always trouble after the car had been serviced.
  13. DragonRR
    DragonRR Karting
    Sep 2, 2021
    94
    Simon
    Dealers recommend always having the car on charge. This is because most owners don't use them enough and the car's battery loses a significant amount of charge per day. If it hits zero you may well end up having to get the car towed off to a dealer.
    Whilst you can drive in electric straight away the car really likes to have a warm engine and gearbox to operate properly. I always fire the engine up and let it warm. You never know when you'll need that extra power.
  14. Puro
    Puro Karting
    Sep 15, 2022
    244
    So the engine can’t operate independently in such a case? What a strange technology. Seems like their next gen hybrids should be fully…hybrid.
  15. DragonRR
    DragonRR Karting
    Sep 2, 2021
    94
    Simon
    This "feature" does seem quite a common one with performance hybrids. More puzzling for me is what on earth the car is doing to drain the main battery in a week or two.I tested mine awhile back (garage temps were low.. maybe 1-10 deg C) I lost 6% battery per day.
  16. jobama1
    jobama1 Rookie
    Mar 15, 2025
    12
    With my Mac the car would talk back and forth with the key, so i started keeping the both keys in a faraday box which helped significantly
    IvanRico likes this.
  17. BeachDoc
    BeachDoc Karting
    Jan 30, 2022
    80
    Virginia Beach, VA
    Paul Johnstone
    I agree there should be an override feature for when the hybrid battery is dead. I had fatal hybrid battery error and had to push the car out of the garage in order to load it on the truck...very frustrating but this is what happens if the hybrid battery fails. Car is still at the dealership while they try to figure out why the hybrid fully discharged despite being on the charger.
  18. Puro
    Puro Karting
    Sep 15, 2022
    244
    Next gen’s need to be chargeless, fully innate hybrids.
  19. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    It doesn't have to be plugged in - and in fact when I bring it back I usually only drive the last 1-2 mi on EV mode to keep it stealthy in town so I tend to have about a 90% charge when I park it. The 296 then indicates that it can go 90+ days without needing to be plugged in. I have no problem leaving it for weeks or more without being on the charger.
    Like all EVs, the key is to not leaving it <25% charge, in extreme cold or with the lights on or keys in it. That avoids extra parasitic drain that will more quickly discharge the PHEV battery.
  20. DragonRR
    DragonRR Karting
    Sep 2, 2021
    94
    Simon
    I have no idea where your car or app is telling you it can go 90+ days. My app just shows a percentage remaining and it loses 6% per day consistently. I haven't let it drop below maybe 20% and perhaps the car tries to lower the drain at some point but I haven't seen any sign of that and several dealers and techs have told me about owners having their cars transported in to get them up and running after pretty short stints of being garaged.
  21. ntatfas
    ntatfas Formula Junior
    Apr 27, 2011
    279
    Here is my experience after 18 months owning first a GTB and now a GTS.
    The GTB just worked, plugged it in when I returned to my garage and never had a problem. If I was away I drove the last few miles in Quali mode and the Hybrid would drop 3% (summer) or 5-6% (winter) per day if I did not drive it and it was not plugged in. Eventually I just got into the habit of driving the last few miles in Quali mode wherever I was.
    Unless the hybrid was low (perhaps < 20%) it would start in Electric only mode if I wanted, if it was low it said no electric start available and I would start it in Hybrid or ICE only.
    GTS arrived, within 6 weeks the hybrid was dead even though I followed my normal procedures. Eventually worked out I had a power cut in the garage and after a lot of detective work it appeared the charger had feed the hybrid's charge back into the garage and the 12v battery had been hammered.
    Because of the power cut we left it at but the car had to go back to the dealer for the "dead" hybrid to be resolved which should have told me something**
    I was then on a road trip and had the 12v system fail. Luckily I had a NOCO to help charge the 12v and all was ok.
    **Eventually traced both the GTS electrical problems to the charger being faulty, got a new charger and no problems since.
    My lessons:
    – plug it in where possible
    – use quali mode to charge the hybrid to your final destination if possible
    – unplug the charged if you have a power cut
    – use the app to check the hybrid charge level
    – do not use an extender with the Ferrari supplied charger
    Enjoy the car :)
  22. Caeruleus11
    11,485
    Ive also had it suggested to me that it’s a good practice to unplug the tender every few weeks as this seems to reset its internal computer. First unplug from the car, then unplug the tender from the electric main. Im not so sure how long to wait, I usually leave it for an hour or so. This has worked for me.
  23. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    When exiting the car, the “My Drive” screen shows a “battery life” with a number of days. Maybe this information is wildly overstated but I do know I’ve left the car for many days and returned to find a similar charge. The car is kept in a garage that doesn’t go below 55 degrees F, the keys are in another room.
    I’ll keep an eye on the app to see how much it drops per day. Obviously I too do not wish to have a dead battery require me to flatbed it to the dealer, but I do expect the car to work as advertised.
    DragonRR, PieGre, rg88 and 1 other person like this.
  24. Puro
    Puro Karting
    Sep 15, 2022
    244
    So it’s basically just a plug-in toy. Ferrari needs to get on their R&D game and make their next batch of hybrids innately hybrid.
  25. Puro
    Puro Karting
    Sep 15, 2022
    244
    Cool deal. My only concern is complexity. This would be for a rental portfolio, and I wouldn’t want customers dealing with nightly charging woes. Might be best to find a slightly used F8 instead.
