Starting FF | FerrariChat
Starting FF
Discussion in 'FF/Lusso' started by LeoBRK, Sep 9, 2019.
  1. LeoBRK
    LeoBRK Formula Junior
    Sep 26, 2010
    454
    NYC
    Leonardo
    So I just purchased 2014 FF and i am loving every minute of it! however, When i start the car and put the key in the proper setting and hit the start button the car does not turn on - nothing. All the sounds and lights noise radio everything is on and there are no check on lights on , so all good. Take the key out and try again nothing, after the 3rd time it usually starts? The battery 'seems' to be fine. The car just past CPO inspections etc and the battery was fine, i even have a separate document just for the battery inspection. I have driven the car ever day for 4 days , 3 times for apporx 30 miles each trip.Am I not stepping on the brake pedal hard enough? Am I doing something wrong? Or is this just the ugly battery debacle on these cars starting already?! I would think if it was the battery I would have some Warning light or it would should low battery or all the bells and whistles would not be turning on once key is in the ignition?
    Otherwise AMAZING CAR!
  2. ttforcefed
    ttforcefed F1 World Champ
    19,218
    on my 430 is was the brake pedal sensor - if i put all my weight on the pedal the car wld start - id i didnt, i got nothing. try and stand on the brake pedal.
    Caeruleus11 likes this.
  3. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    Thanks i’ll try that when I leave the office thanks
  4. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,335
    The Netherlands
    Are you holding down the starter button or just prodding it? Mine needs to be held down until the engine fires to guarantee the start. Sometimes a prod of the button will do but it doesn’t always guarantee that the engine will catch. At which point I get a Christmas tree light display of error messages.
  5. sampelligrino
    sampelligrino Formula 3
    Apr 16, 2017
    1,245
    Might be mistaken but aren't you "supposed" to put the key in the ignition/start position, then wait 5+ seconds to let systems communicate and wake up before actually hitting the start button on the steering wheel starting the car?
    On my 488 I have keyless but I still do this based on what some 458 owners had said. Just an idea
    AlfistaPortoghese likes this.
  6. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    Yes I guess I should hold it down a little longer correct sometimes with just a touch it goes sometimes I have to hold it down. that makes sense I should just wait five seconds until the systems run their updates. just got in the car and hour ago and it was fine. I’m pretty certain the batteries fine I suppose I just want to get in the car fired it up and RUN!! I I’ll try to be more patient :)
    ingegnere likes this.
  7. IloveGT
    IloveGT Formula 3
    2,419
    Hmm? That's weird. If the pedal not pressed hard enough, it will actually tells you to press harder. Is it your start button acting up?
  8. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    lets see whats happens this am when i get it out.
  9. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Yes.
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    This is a well known issue for the 360/430, but I've yet to see it being the case for the later generation of cars. I think it's quite specific to the 360/430 and does not really apply here.
  11. ttforcefed
    19,218
    Ahh. Makes sense. Look forward to seeing what the issue was.
  12. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    Started perfect after work last night, sat in my garage for about 14 hrs last night, no issues starting- fired right up. I now wait for 5 sec its all good
    thanks guys
  13. ttforcefed
    19,218
    fwiw i def dont wait 5 second....as soon as the key is turned i hit it!
  14. IloveGT
    IloveGT Formula 3
    2,419
    I don't have to wait as well. I do hold the start button until the amazing v12 engine roar is heard by the grandma next house, that usually is about 1-2 seconds only.
  15. ttforcefed
    19,218
    yep button needs to be held in until it comes alive
  16. TriumphantTaco
    Sep 27, 2018
    13
    Had this same issue with my 2012 FF. Came home after a long trip (car was on battery conditioner the whole time). Failed to start and the solution was to press the brake pedal much harder. i didnt get that suggestion from the car. I was just so pissed that the car wasnt starting that I ended up hammering the brake pedal in frustration while the button was pressed. The sound of the v12 quickly removed all my frustration!
  17. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    interesting, i now wait about 3/5 sec let the computer go through its diagnostics and firmly hold brake pedal and its good to go!! Yes that sound makes it all worth it :)
  18. ttforcefed
    19,218
    Thats how I figured out the sensor needed to be replaced in my 430
  19. otakki
    otakki Formula 3
    1,634
    Definitely need to wait for the key and car to communicate first before hitting the start button. I think the okay is given when the letter ?P (?parking) shows up on the dash; at least that's what I recall from the manual.
  20. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    I've owned two FFs and three Californias since 2010 with probably a total of 140,000 miles between them all in daily driving. A modern Ferrari requires no delay between turning the key on and hitting the starter! I simply put my foot on the brake, if stiff then press hard, turn on the key and immediately press the start button If that doesn't work then something is wrong with the car. My 2019 GTC4Lusso has no old style key. In that car I press the brake and press & hold the start button with the keyless thing in my pocket. There is a 2 second pause between pressing and holding the button and engine start built in.
    I know nothing about Ferraris before the California though, possibly they need waiting. About twice a year (of DAILY driving) there might be a communication issue that causes all kinds of warnings but a shut down - open and close door - and restart always fixes it. The delay or not delay has nothing to do with it.
  21. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    For a cpo I’d be pissed and have them fix it.
  22. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    Been driving the car for over a week and it’s had not happening again ? See what happens moving forward
    ANOpax and Natkingcolebasket69 like this.
  23. ttforcefed
    19,218
    its italian - dont worry about it!
    mpdugas and Natkingcolebasket69 like this.
  24. Natkingcolebasket69
    It’s Americanized though: I miss the honk from the Testarossa ; the gearbox that has a mind of its own and The faulty slowdown sensors days;)
    ANOpax likes this.
  25. LeoBRK
    Sep 26, 2010
    454
    NYC
    Leonardo
    LOL yes so true.
