360 - starting problem | FerrariChat
360 starting problem
Discussion in '360/430' started by Mauricio360, Dec 12, 2019.
  1. Mauricio360
    Mauricio360 Rookie
    Apr 29, 2012
    15
    Denver,CO
    Mauricio
    Thanks for looking
    i have 360 spider that will only slowly start in the morning. the rest of the day it starts just fine.
    https://www.dropbox.com/s/303xleit79d0o0e/IMG_5945.MOV?dl=0
    - The battery is brand new and fully charged.
    - the garage is heated to 55 F
    suggestions are welcomed. I am hoping someone had a similar problem
    Mauricio
    360 spider
  2. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    How many days is your car sitting before you start it up? The battery may run down a little and then charge back up while driving
    Sent from my SM-G975U using Tapatalk
  3. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    Several possibilities, and a number of posts on the subject herein. Next time, turn off the ignition before it starts. Then try again. Bet it starts right up. But do read the previous posts.
  4. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    590
    SW Suburbs of Chicago, IL
    Lawrence P.
    Are you using a battery tender to keep the battery at a peak level?
  5. Mauricio360
    Mauricio360 Rookie
    Apr 29, 2012
    15
    Denver,CO
    Mauricio
    the car is normally plugged into the battery tender. The battery is only a month old
    Shad99, i will try turning off the ignition before it starts and try again.
    I am bothered this problem is new and will get worse. The lag is about 1 or 2 seconds before the car tries to start. Which is new
  6. SnowmanUK
    SnowmanUK Karting
    Dec 11, 2010
    174
    London, UK
    It sounded like the F1 pump was still running when you turned the ignition to start the car. I wait for the pump to stop (the whirring sound that also occurs when you open the driver's door) before starting the car.
  7. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    Stomp on the brake before you start. If the engine stumbles -- pulse the brake pedal after the engine lights. If modulation of the brake pedal causes the engine to rev normally, you have a vacuum leak in the brake booster circuit. If you have a later model 360 -- check the Ricambi 360 web site or your favorite parts vendor -- Table 41 to determine what brake booster system you have in your vehicle. If you have the check valve -- part no. 24 -- it is likely it has failed. Otherwise, you will need to put a vacuum gauge on the circuit and test. It could be the booster itself, but these devices are generally bulletproof for obvious reasons.
