starting procedure | FerrariChat
starting procedure
Discussion in 'Technical Q&A' started by veryfast355, Jun 25, 2008.
  1. veryfast355
    veryfast355 Karting
    Sep 24, 2007
    120
    gt neck long island
    michael c
    I am curious as to the method of starting the car from cold ; I start my 355 and let it idle for several minutes before moving the car.I always wait for the vacuum pumps to finish ' whining '' - Any recommendations from other members?
  2. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    #2 eric355, Jun 25, 2008
    I don't think it is necessary on a modern car to have it idle several minutes before moving. What is really important is to be very gentle on the throttle pedal and the revs until the oil is fully warmed. BTW, having your car idling before moving is only warming the engine but not the gearbox. So, start it, drive it cool until all is at nominal temprerature and then ... GASSSSSSSS :)
    Oh also, this famous pump is not a "vacuum" pump, it is a classical pump which blows some air (oxygen) in the exhaust to burn the remaining fuel during the extra-rich warm-up phase and avoid the cats to overheat.
  3. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    +1 as Eric.... i put the key in...turn it to the on position, wait 5 seconds, then start it. once all the ABS lights etc go off, i start it out in first gear, rolling down the block slowly for about half a mile until the temp gauges are up, then I'm good to go!
  4. veryfast355
    veryfast355 Karting
    Sep 24, 2007
    120
    gt neck long island
    michael c
    Thanks guys- that makes a lot of sense
