Starting question | FerrariChat
Starting question
Discussion in '308/328' started by syata, Apr 4, 2019.
  1. syata
    syata Formula Junior
    Feb 23, 2017
    428
    I have a 1988 328. I wanted to find out what the proper starting process is on a 328.
    Do you turn the ignition key to the first position and wait until the red indicator light and buzzer of off or do you turn through the first key position to ignition and release the ignition key once the car started?
    Thank you.
  2. syata
    Feb 23, 2017
    428
    Correction...1986 328.
    The owners manual I have does not mention the buzzer and lights.
  3. thorn
    thorn F1 Rookie
    Aug 7, 2012
    3,324
    Tallahassee, FL
    I start it like every other car I've ever owned. Turn the key on, full to the right, crank the engine and drive away...
    Martin308GTB likes this.
  4. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,294
    Black Forest Germany
    Martin N.
    I do not believe, that a 328 needs any special starting ritual. As opposed to a carbed Euro car, where it's recommended- especially after a longer resting period- to let the fuel pump run for a a while on key's 1st position, till it alters its sound, what shows, that the float chambers are filled :)
    Best from Germany
    Martin
  5. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    406
    PA
    Alex
    I kind of pause for a brief moment in the On position, before fully turning the key to Start, not because I have to, but to ensure I admire the beautiful displays before heading off.
    Milkshaker0007 likes this.
  6. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    A cold start just turn the key without using the throttle. When engine is running the ABS light burns for few seconds to do a system check. The right red light for the dynamo burn until making few more revs. Make sure the oil pressure is o.k. and you can go. Hot start is the same but requires some assistance from th throttle.
    waymar likes this.
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,614
    California SF bay area
    Paul
    On K-Jet the fuel pump does not run until engine cranks and the incoming air moves the metering plate so waiting in the first position does nothing.
  8. eyeman1234
    eyeman1234 Formula 3
    Dec 25, 2006
    1,882
    Boca Raton, FL
    bertrand328 likes this.
  9. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    I have the same feeling with 3x8 that have extreme low milages. The seals and packings need all replaced and even revving on the starter with some oil on top of 8 pistons must result in damge all over.
  10. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    When its cold I tend to wait for the ABS pump thing to stop making a racket before I crank it. I can't recall if that's what I was told to do 20 odd years ago when I bought the thing , but its what I've always done!
