Starting search for 430 | FerrariChat
Discussion in '360/430' started by Lipets, Dec 28, 2024.
  1. Lipets
    Lipets Rookie
    Dec 28, 2024
    2
    First Post!
    What years have what problems?
    Any preference to any year(s)
    I understand so far Check clutch wear, whether the headers have been upgraded from the MK1, if its an 05 that it has the upgraded f1 pump ( simple test is to open the drivers side door and hear the pump prime. Should be under 10 seconds), F1 hoses, sticky buttons,tail lights, mirrors etc.
    What do the stock coil overs look like to identify them
  2. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    282
  3. Pete Schweaty
    May 21, 2014
    282
    A few more I thought of. Check the motor mounts, and clutch life.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    One of the better ways of 'starting your search' is to learn to search - there's fifteen years of 430 buying experience shared here including check lists and a master list of upgrades & changes by assembly number etc - use them and you'll be well on your way
    GogglesPisano and flash32 like this.
  5. Lipets
    Lipets Rookie
    Dec 28, 2024
    2
    did that way too many issues to deal with, I'll pass
  6. GogglesPisano
    GogglesPisano F1 Rookie
    3,218
    East Bay, California
    Joe
    Not to come off as rude, but if you can’t be bothered to search and just expect everyone to give everything to you, you won’t get very far on the forum. The search function works quite well and can be supplemented by searching google and sticking “FerrariChat” in quotes to limit results to this forum.
  7. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    If you want to be an owner you're already armed with the information you need.
    If you want to be an enthusiast then spending time on this forum will yield the most indepth information unavailable elsewhere, with real experts that bleed Rosso Corsa to help you in a tight spot.
    Good luck with your choice either way.
    swc5150, DutchFerrari and flash32 like this.
  8. dmijoskov
    dmijoskov Karting
    Oct 8, 2011
    76
    Palm City, FL
    Danny Mijoskov
    Hope my video can help.
    Paul Kane likes this.
  9. swc5150
    swc5150 Formula Junior
    727
    Wisconsin
    Scott Calderwood
    Issues with owning a 430? It's actually a very easy Ferrari to live with.
    colorfull likes this.
  10. Mario Andretti
    Mario Andretti Formula 3
    1,779
    Boston
    Easiest car to fix anything - so far - I have ever had.
    swc5150 and colorfull like this.
  11. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    778
    Bollenstreek - Netherlands
    Jeroen
    I 2nd this!
