Starting stored 308 "Precautions"? | FerrariChat
Discussion in '308/328' started by Uralguy, May 5, 2013.
  1. Uralguy
    Uralguy Rookie
    May 4, 2013
    4
    Ca.
    Bill Henderson
    Hi, I'm new to FerrariChat. My 1985 308 Qv has been sitting in storage for over a year without being started, what precautions should I take before firing it up......Oil in cylinders to free up rings? any suggestions would be appreciated.
    Bill
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    How long over a year? How was it running before you stored it, has it been started at all in the interim & how much gas is in the tank?
  3. Uralguy
    Uralguy Rookie
    May 4, 2013
    4
    Ca.
    Bill Henderson
    Hi Iain , The 308 has been stored for a little over a year, it has about 3/4 of a tank of gas and I drove it up till the day of storage, just before storage it had an oil change and new plugs. It ran great. At the time of storage I didn't make any precautions about storing it.....oil in the cylinders etc.
    Bill
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    The risks (and nobody can tell you whether it will be a problem or not):
    Bad gas could cause a problem depending on what grade (and ethanol concentration) it had in it.
    Cam belts/bearings could be an issue (and that would be expensive) - obviously less likely to fail if they were relatively young
    You might see cam oil seal leaks after you start running it
    On balance, and if the belts & bearings were not too old, I would turn the key & start it. Maybe put some oil in the cylinders first but its unlikely to kill it if you don't.
    You might want to roll it backwards and forwards before you attempted to drive it to make sure the brakes/parking brake are not stuck on - and check the tyre pressures too.
    But its not mine. :)
  5. Uralguy
    Uralguy Rookie
    May 4, 2013
    4
    Ca.
    Bill Henderson
    Thanks for the Info!
    All the best
    Bill
  6. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Check for puddles under the car to make sure it didn't leak out all of it's lubricants.
    Look for rodent damage to wiring or in the airbox.
    Turn the key on and check for fuel leaks.
    After that I'd turn it to START.
    Once running, give the brakes a few test applications before you hit the road for that Italian tune up!
  7. Glassman
    Glassman F1 World Champ
    I'd drain the old gas, put some new in and start the car. I once ran stale gas thru an old jag and the ensuing headache was well massive.
  8. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Mine was stored for a long time, and I have had it sit for 8 months. Yes the gas will be stale. If it were mine, I would top off the tank with new gas, and drive it. Run it down a 1/4 and top her off again.
    I Have also had boats sit for extended period with out "Stable" in the tank. and I have just topped it off and fired it up.
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I also lost a Jag to separated gas that filled the system with water which is collected at the bottom of the tanks where the pick-up is. Just gave that XJ6 VDP away as a tax write off to a charity for the deaf.
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Turning the engine by hand at the crank would circulate some oil no?
  11. GT4 Joe
    GT4 Joe Formula Junior
    Oct 19, 2010
    833
    Dana Point, Ca.
    Joe Williams
    Good advice above. How's your Karma?
  12. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    I haven't found any good advice on how to manually prime the oil pump without a lot of trouble, but you could always pour some oil directly into the middle hole of the oil filter pipe with the filter removed, it will go right where it needs to be. If you're concerned about over-filling, just change the oil while you're at it (a good idea in case of moisture collecting) or run a thin siphon down the dipstick tube.
    Wouldn't hurt to pull the gas pump fuse and crank the engine a bit to get the oil pump moving, and the parts of the engine moving at a lower speed and without the stress of combustion. You could take the plugs and out disconnect the ignition too so there's no compression, and let you put some oil directly in the cylinders, but IMO that's optional. Rule of thumb is let the starter rest equally as long as it was cranked before the next one, and definitely not longer than 30 seconds, I would say 5-10 seconds max personally.
    Other major issue is fuel, I agree with others that you should drain if possible, and put fresh in it. Then if you want to be really careful, remove the safety wire going to the fuel distributor and turn the key to "on" without starting, and let the fuel system run and look around for any new leaks.
    And as others have pointed out, check your brakes before getting it out on the road.
  13. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Lucas makes some stuff you can add to order gas to help get through your existing tank. I found it at walmart, and put about 3 times as much in as they suggested. It also has some sort of cylinder lubricant in it.
    Doug
