355 - starting the engine after a long stop ... | FerrariChat
355 starting the engine after a long stop ...
Discussion in '348/355' started by evo11, Nov 12, 2021.
  1. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Guys,
    I'm planning to install an immobilizer that I want to use in order to turn the starter to fill the oil, but without starting the engine. I meant 3-4 weeks of car stop.
    Do you have any idea what I could cut off? I thought about fuel injections, but I wonder if the computer displays errors?
    Thanks K
  2. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,049
    Atlanta, GA
    Steve D.
    Define a long stop? 3-4 weeks is a maintenance downtime. It'll be fine.
    sjd
  3. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    for the oil pressure is an issue, it's always take some time..
  4. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    I don't get why you need to install a special immobilizer here. Maybe this doesn't work on a 355, but on my 993 you can just pull the DME relay, crank the engine over until you see oil pressure, plug the relay back in, and fire up the car.
  5. Qavion
    Qavion F1 World Champ
    14,262
    Ian Riddell
    #5 Qavion, Nov 12, 2021
    Attach a remote starter button to your starter motor. Use it with the ignition off (and out of gear of course)
    https://www.ebay.com.au/itm/194007970091
    Disconnect the small plug and attach one of the leads to the pin on the starter, then attach the other lead to the big terminal. Push button.
    steved033 likes this.
  6. Qavion
    14,262
    Ian Riddell
    I guess the equivalent (F355 5.2) relay would be the passenger footwell "M" relay. This will kill the fuel pump and ignitors (and a bunch of other things), but I don't know if this will latch any fault messages in the ECU. My car recently latched a fuel pump relay message (no CEL) after a long period of inactivity.
  7. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Good idea ! Thanks !
  8. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    It could work too !
  9. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
