Afternoon Austin, the sensors are located on the clutch bellhousing. Looking at the engine from the drivers side, you will see the bellhousing. One sensor is slightly left of the oil filter and the other one is on the right, next to the oil line that goes to the oil cooler. Both sensors are in an oval hole, locked with two 8mm nuts. Also to mention is that the sensors are interchangeable, in other words, they are exactly the same. Hope this helps! John
