Static balance with CCM brake rotors attached | FerrariChat
Discussion in 'Technical Q&A' started by RayJohns, Dec 5, 2016.
  1. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I touched on this question here, in the 458 section:
    http://www.ferrarichat.com/forum/458-italia-488/528395-458-not-stable-high-speeds.html
    But I wanted to ask it in the Technical Q&A area also...
    My question is this:
    Has anyone ever used a motorcycle type static wheel balancer to balance their tires (in this case, I'm asking about the 458 Italia) - and if so, what were the results?
    Additionally, has anyone ever gone to the extent of attaching the CCM Brake rotors to the wheel/tire assembly, in order to balance the entire assembly as a unit? Again, if so, what was the outcome.
    I've purchased some cones and a wheel spacer which I intend to use and/or modify so that I can do my own static balance on my 458 front wheels. I've had very good luck balancing my motorcycle tires, so I don't see any reason why I can't produce the same results myself on the Ferrari wheels.
    If anyone else has done this using a manual static balancer (not the spin type tire shops have, but the kind where you find the heavy/light spot of the wheel/tire yourself and then counter balance until the wheel/tire stays statically positioned), I would love to hear from you regarding your experiences.
    Thanks!
    Ray
  2. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    184
    Los Angeles
    Jim Oddie
    The motorcycle static balancer probably works for motorcycle wheels because they are narrow, so the distance from one side to the other is small.
    With a wide car wheel, the wheel / tire could be in balance in one plane but be out of balance in the other plane. In other words, if there is too much weight on the inside at one point and too much on the outside at a point on the other side of the wheel, it would balance on a static balancer but would tend to wobble once spinning.
  3. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    The rear tire of my motorcycle is fairly wide and I have never had any problem static balancing it by placing the weight directly in the middle line of the wheel.
    On the car tire, I plan to put the weights in the center line of the wheel and if that doesn't work, then I'm going to split up the total weight and put 50% on the inside and 50% on the outside.
    I'm going to also research how automotive tire balancers work as well.
    It will be interesting to see how it all works out in the end :)
    Ray
  4. tazandjan
    39,312
    Ray- Why bother when it costs very little to spin balance your wheels and tires and know there are no problems? Your static balance system will never detect an out of round wheel or a tire with a manufacturing defect. I have mine force balanced to make sure there are absolutely no problems.
  5. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    My current tires were balanced by a machine (at the Ferrari dealership) and I have to say I'm not all that impressed. Far too much vibration.
    I believe I can do a better job balancing the tires myself, using a static balancing method. With the motorcycle tires, I balance them to approximately 1/4 to 1/2 of a gram. That's approximately the weight of a 1" length of scotch tape. I don't think the machines they use at tire shops do as perfect a job. I think they balancing they do is usually plenty good for most cars and probably even for track stuff, but I just feel like doing it the old fashion way, by hand, might yield superior results.
    If I'm wrong, then that's okay and I will make changes down the road. For now, I am going to explore this method of balancing car tires and see what sort of results it produces. I just don't believe there is enough difference in how a motorcycle tire needs to be balanced vs. a car wheel.
    Like I say, perhaps I'm incorrect in my thinking, but I like to do my own tests and see what sorts of results I can achieve, as opposed to just going with the masses and accepting that a machine always produces better results than doing it by hand.
    So, we'll see soon. I have most of the parts here to setup my jig. I'll post picture if I make some progress as well as whatever results I end up with - good or bad.
    Ray
  6. eric355
    eric355 Formula 3
    1,231
    Toulouse (France)
    Eric DECOUX
    Dynamic wheels balancing does 2 things:
    - put the Center of Mass on the rotation axis
    - align the wheel inertia axis on the rotation axis (in other words to align the natural rotation axis of the wheel on the hub axis)
    To achieve the second, you have to put weights away from the wheel middle plane, at locations depending on where is the actual inertia axis. By using inner and outer weights of different values you can compensate for both. That is exactly what balancing machines are doing.
    Static balancing will only allow you to compensate for the position of the Center of Mass, but not to correct the inertia axis. For that you have to spin the wheel and measure the transverse torque modulation on the hub.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #7 2NA, Dec 12, 2016
    Have them rebalanced by someone that knows how to do it right. Don't be fooled by the fancy sign on the building. Take them off the car and truck them over to a reputable tire shop, balancing tires is their business.
    A bubble balancer won't get the job done with tires that wide. I have one client with a Maserati Ghibli. The wheels have such a small center hole that they won't fit a spin balancer. I've got a bubble balancer that I use just for this car. With the 215/70R-15 tires it works well but not for anything much wider.
  8. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I've seen those bubble balancers; that's not what I'm using here. I'm talking about the static balancer where you suspend the wheel on an axle, then allow it to rotate to the heavy location and offset that area with weights.
    When I have a minute, I'm going to do a little more research into the difference between static and dynamic wheel balancing. However, I still feel like if it works for a motorcycle wheel, it should work pretty well for a car wheel as well.
    Ray
  9. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    Here is some helpful information on the subject:
    Hunter GSP9700 Wheel vibration Control System solves wheel vibration and tire pull problems that balancers and aligners can't fix
    One thing I'm going to do, also, is static balance the brake rotor independently of the wheel - and then pair the two together so that the light spot in one helps to offset the heavy spot in the other.
    I think that will also help to move some of the mass more to the center line of the whole assembly, which might help me out as far as not doing any sort of dynamic wheel balance. With that said, I wonder if mixing a bubble balancer with the rotating static balancer might come at the problem from two different directions.
    Like I say, I am still doing research on the whole idea. If I do the static balance, I'll report back as to how it all goes. Right now, there is some vibration in the steering wheel, so whoever mounted these tires didn't do much of a job balancing them.
    Ray
  10. ago car nut
    ago car nut F1 Veteran
    5,521
    Madison Ohio
    David A.
    Ray, I had 3 different bubble balancers. I could not get them to repeat if I took the wheel off and replaced it on the balancer. The way you are going to balance between cones suspended on a mandrel. That is the way we balanced big grinding wheels in the machine shop. Never seem to have a problem with them. They turned some hi rpm. Interested to see how you make out.
  11. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    That's sort of how I feel too. I've had very good luck balancing motorcycle tires here using this static balancing approach. When I first purchased my bike, I had awful vibration that took a long time to track down. I finally tracked it down to the tires/wheels.
    I've seen plenty of so-called professionals balance tires and I have never been impressed with neither the time spent, nor the final results. Now, there may be some exotic racing shop out there or wheel/tire place, where people pay attention to detail and actually have read the entire manual for their fancy computerized wheel balancer, but knowing people in general, I kinda of doubt it.
    Even on my truck, I cringe when I see how they balance the tires. Last time I had a spare mounted, the guy put the wrong tire on the rim. I had to take it back and point out they put someone else's tire on by accident. After that, they came out and told me they were unable to get the wheel/tire to balance. I politely pointed out that they had failed to remove the enormous mount of lead balancing weights that they had put on last time I was there and that perhaps if they did that, then the wheels might balance properly.
    "oh dang, we didn't even notice that"
    Once they removed the old weights, magically the wheel balanced out okay.
    Point is, I have very little interest in "letting the pros handle it", unless I can establish that either the person and/or the equipment they have is superior to something I can do here at my garage myself - with a little ingenuity.
    Right now, my money falls with the "if it works on my motorcycle, it will work on my car". The motorcycle is exponentially more sensitive to minor imbalances in the wheels/suspension than the Ferrari. On the bike, even a 10 degree difference in outside temperature changes the handling. 2 PSI on the tires makes it a different bike all together. So my gut tells me that if I am able to get the static balance within a gram or less, the rest might very well take care of itself.
    If not, I can always go to track down someone at the local track with a wheel machine and see what they have to say for themselves :)
    I'm about to measure some of the fixtures and stuff here, so I'll see if I can post some pictures soon.
    Ray
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You're wasting your time and money. You will need to create a mandrel/hub to mount it to and still won't address the issues presented by the wide tire.
    Unless there's a big piece missing out of the brake rotor, it would be pointless to attach it.
    There's nothing wrong with a modern balancer in the hands of someone that knows how to use it.
    Keep in mind that tires are semi-handmade. There is variability and it is possible that you have a bad one.
  13. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    You're entitled to your opinion and it may very well prove to be true in the long run. We shall see :)
    Ray
  14. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    #14 RayJohns, Dec 12, 2016
    Speaking of wasting money, here are some shots of the adapter I'm setting up as a test. Ultimately I may weld a different axle into the hub, but for now this should allow me to at least accomplish some further testing to see if I'm on the right track or not.
    I'm also wondering if I could setup a dial test indicator to check for wobble somehow (such as on the side of the rim, but not touching it or something). Anyway, so far things seem to be on track as far as doing a test of how the static balance works.
    I may need to expand the distance between the pillars there and/or turn them around for additional clearance.
    Anyway, you get the idea.
    Ray
  15. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I'm not sure if they balance those brake rotors or not at the factory. However, I do intend to mount one up by itself to see if it's statically balanced or not. I'll follow up with what I find just for the sake of interest on this thread.
    I'm also going to switch that little mounting bolt that holds the rotors to the hub to titanium. Not sure about the pin thing yet.
    Once I finish a few other things around here and the kids head back down south, then I will pull a wheel off the car and take a closer look at things.
    Ray
  16. Alden
    Alden F1 Rookie
    3,712
    Central Florida
    The Hunter machines are great - if you have the right tech doing the work.
    I bought the "lifetime" balance for my Jag at the local Goodyear shop that has a Hunter machine for $25 per corner. My Jag has pretty stiff sport suspension and is very sensitive to any out of balance issues.
    I have had the wheels balanced on my Jag twice and have had to go back 3 times, each time, to get the job done right, and this is even when I speak to the manager before they do the job and tell him to get his best tech on it and do EVERYTHING the machine tells them to do to balance the wheels/tires properly.
    I was in pretty good shape until I hit 140 on the back straight at Road Atlanta, then the vibration kicked in. Jeeeeez!
    They are so used to balancing tires on Grandpa's Crown Vic that they don't use all the tools the Hunter gives them or place the weights "exactly" where they need to go.
    Needless to say, I am going to try another location for the Ferrari when the time comes.
    Alden
  17. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    #17 RayJohns, Dec 12, 2016
    That about sums up leaving it to the "professionals" all right.
    I was just reading through a manual regarding wheel balancing and they stated that 90% of the problems encountered during wheel balancing are due to operate error.
    Here is the link to the PDF download:
    www.nussbaum-group.de/deutsch/datenschutz/download_file.html?sse_idupl=4800
    Ray
  18. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Rayjohns,
    I think you are going down the wrong road with static balance.
    How much total weight is on the bad wheel right now from the tire store? Each little square is usually 1/4 oz.
  19. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    The bad wheel I mentioned above was from my truck. That was just an example of how closely you have to watch people at these shops.
    With regard to the Ferrari, I will have to see once I pull the front wheels back off the car. As I recall, not too much. I'll update this thread with my results and findings - good, bad or otherwise. If the static balance routine doesn't work for the car, that's fine with me. However, I still want to try it and see if it works enough to smooth out the vibration I'm getting.
    If it doesn't, then I will try something else or throw in the towel and take the wheels to a tire place and see what they can do using a balancing machine. However, in reading over how the tire balancing machines determine where to place weights, it appears it's largely a function of movement of an extended lever off the center axis, which is transmitting and magnifying the wobble produced by uneven weight. If that's the case, I might be able to measure that using something like a dial test indictor myself.
    A lot depends on how much balancing is actually needed here. As mentioned before, I balance my motorcycle tires to between 1/4 and 1/2 a gram (static balancing). That's well beyond the balance done at most tire shops. I'm guessing they are balancing only to about 1/2 an ounce, which is about 14 grams. For me, at least with my experience with balancing motorcycle wheels, 14 grams is a gigantic amount of weight. Even 1 or 2 grams is huge.
    I remember a few years ago I was given a small tour of a military base where they work on Marine Attack helicopters. I can't remember if they let me sit in a Cobra or something else, but I asked the guys how accurately they balance the helicopter rotors. 5 grams.
    I'd let that guy balance my tires anyway.
    The main reason I'm investigating this isn't because I have some distrust of the tire balancing machines at tire shops. I think they probably do a nice job balancing the tires. The issue I have is with the people running the machines. I don't have a lot of faith that they actually know what they are doing or that they are paying attention to details enough to actually produce a high quality balance which will be smooth at higher speeds.
    Anyway, we'll see how it goes soon enough :)
    Ray
  20. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Where are you on the west coast? I'm near redondo beach. I have my own tire mounting machine and dynamic spin balancer. I do lots of race tires. They are my biggest annual expense. I can tell you lots about balancing and you are right about the well-intentioned tire guys who are just ignorant of how to balance a tire. And did you know many club racers rebuild our shocks annually? That adds +$1000 minimum to our annual race budget. People have streetcars 20 years on the same shocks.
  21. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I'm about 5 minutes away from Laguna Seca.
    I just rebuilt and tuned the front Ohlins forks on my Yamaha R1 . So yeah, I believe you :)
    Ray
  22. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I've been sitting here trying to think about how I could address issues of balance relating not just to static balance, but also dynamic balance (i.e. wobble due to unbalance areas in different areas of the tire).
    I wonder if part of the jig was on mild springs and then you used a drill (or something) to spin the tire up to 1500 RPM's. That would be about 120 MPH. If the tire was unbalanced, it would cause the tire and fixing axle to wobble a little bit on the springs. This would allow the tire to move very slightly, which would allow the use of a marking pen to mark the wheel in the location where the excessive weight caused to to move back and forth.
    Just thinking out loud here, but I wonder if something tricky along these lines could be made that would allow you to zero in on where the tire was heavy or light when rotating...
    Ray
  23. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Too bad we live too far apart. Before you do anything measure the runout on the wheels and then the runout on the tire/wheel combo. 0.20" at the wheel rim you can feel at speed. No amount of balancing is going to disguise at out of round wheel. 0.40 out means get the wheel fixed or get new one. I use a hydralic ram to bend back my race wheels. We jump apex curbs and bend wheels. After a few seasons we junk them.
  24. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I hope you mean .040" :)
    Ray
  25. fatbillybob
    Aug 10, 2002
    29,252
    socal
