430 - Steel rotor replacement with different size on scuderia | FerrariChat
430 Steel rotor replacement with different size on scuderia
Discussion in '360/430' started by Ahtim, May 9, 2022.
  1. Ahtim
    Ahtim Karting
    Nov 8, 2018
    92
    HK/China/England
    W
    Hi, the stock ccm rotor on scuderia is 398, and if I change it to the 380 size which I saw someone did, how are you going to sort out the brake pads? Do you trim the brake pad or what do you do?
    Also I know that a lot of f430 ccm owners which is the same caliper as scud, but changing it to 380 steel rotor, how do they sort the brake pad out?
    Thanks in advance
  2. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Pretty sure r&b racing rotors sells that sz I just got a set of steel 380mm with pads shipped for $1700
    Sent from my SM-G996U1 using Tapatalk
  3. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
  4. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
  5. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,169
    Why not just buy 398 mm rotors from Girodisc?
  6. windsock
    windsock Formula 3 Rossa Subscribed
    Nov 29, 2006
    1,153
    This, run them all the time.
    Island Guy likes this.
  7. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    Using Giro disc on my setup
