Steep Drive - HELP | FerrariChat
Steep Drive - HELP
Discussion in '360/430' started by swhite7007, Jul 26, 2013.
  1. swhite7007
    swhite7007 Rookie
    Jun 27, 2013
    26
    San Antonio, TX
    Scott
    Just took delivery of an absolutely mint 2003 360 - best first drive in my entire life. Only one problem, I have a steep drive and I underestimated how low the front of that car was going to be. First time up I scraped the pan a little bit - really not all that bad, but I dont want to do it every time.
    I am thinking of a way to tackle it. My idea is to take the hill sideways at first with the passenger side wheel, and once Im a good way up I will turn into the hill to avoid taking the hill straight on. Do you think that will avoid dragging the pan?
    Thanks for any help and advice.
    Scott.
  2. Ferrari-F1
    Ferrari-F1 Karting
    Jul 12, 2013
    238
    Southern California
    Taking the incline at an angle is always good. Also take the dips slowly. It's a low clearance and definitely something to get into the practice of with these cars. Enjoy your new ride!
    Btw, did you get the spider or coupe? Do you have pics to share?
  3. Pzerohero
    Pzerohero Karting
    May 28, 2013
    70
    2 Planks of wood... used to get racecars onto trailers everywhere
  4. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    I think that would work if he had a huge curb to get over. But I'm not sure that's what the OP claims is the problem. If it's a steep driveway, not just a curb problem, then the only real solution is to go at an angle, and hope for the best. Also, not sure if they'll help, but maybe some skid plates? I have a huge curb, and had them installed on my car. They're probably more appropriate for a curb problem, and not so much a steep driveway problem.
    I would not recommend going up in reverse for obvious clutch wear reasons.
  5. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    I have a similar issue when I moved.
    I always go up on an angle and it seems to just clear without hitting, the other is to put a plank at bottom of driveway to lift the nose an inch or so higher so it does not touch. The worst case solution is to get the concrete redone at less of an angle and be more gradual. I hate that scraping sound, it make me cringe
    Good luck
    Glenn
  6. vrsurgeon
    vrsurgeon F1 World Champ
    16,460
    Charleston, SC
    Curt
    Gotta hit it at a 45 degree angle. Then turn into the driveway.
  7. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    Good answer.
  8. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,805
    San Jose, California
    Yes, hit it at an angle, and get some skid plates.
  9. swhite7007
    swhite7007 Rookie
    Jun 27, 2013
    26
    San Antonio, TX
    Scott
    perfect - thanks guys. Wanted to test my logic before I gave it another go. There is no curb, just a sharp rise in elevation. I can hit the drive at a very sharp angle - up to 60 or 70 degrees if needed.
    Appreciate the help.
  10. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    Skid plates will protect the car, but remember... they'll also "lower" the front end a bit making the car more prone to hitting the ground.
    I'd first try the angle-approach to see if you can clear the ground at all. If scraping is inevitable, then skid plates for sure.
  11. redcaruser
    redcaruser Formula 3
    2,426
    switzerland
    daniel
    Shouldn't it work, lift your car a little bit, the chassis is adjustable. I know, this is the absolute worst case for a Ferrari driver...
  12. Pzerohero
    Pzerohero Karting
    May 28, 2013
    70
    Has anyone fitted a lifting kit to a 360??? Cost?
  13. Ferrari-F1
    Ferrari-F1 Karting
    Jul 12, 2013
    238
    Southern California
    I would be interested in the cost and more importantly what the finished product looks like also on a 360 specifically.
    If anyone has undergone this and has pics of the finished look can you please share them with us?
  14. Skidkid
    Skidkid F1 Veteran
    9,497
    Campbell, CA
    John Zornes
    Haven't done it but thought about one. Ramlift makes one and it isn't too expensive BUT you will need to replace the springs as well because it fits under the springs.
  15. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    +1; concrete work is probably less than one nose repaint.
    Also +1 that skid plates lower effective nose height ( I have them anyway, and mine are "used" )
  16. wahoo5
    wahoo5 Karting
    Nov 9, 2009
    182
    Richmond, VA
    David
    If your driveway is like mine and the side edges at the entrance are rounded up, then it works for me to approach at an angle and put the front tire from one side on the curved up edge of the driveway. Works like a charm for me and, best of all, it is free!
