Steering column switch assembly | FerrariChat
Discussion in '308/328' started by Irishman, May 25, 2024.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    I am trying to remove the steering column switch assembly from my '78 308. I removed the two screws that hold the assembly in place. I pulled it out to the edge of the housing but now am hitting stiff resistance. Is it okay to yank on it hard without breaking anything?
  2. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Did you disconnect the three cable plugs?
    Once disconnected you have to feed the black cable cover through the black housing
    I believe the black housing is also secured with one screw to the steering column.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
  4. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Thanks for the replies and especially the pictures, which made it easy to complete the removal. Any suggestions regarding further disassembly?
    I've been searching for threads on the subject. Nothing is broken. I just want to clean contacts that are causing the turn signal to be finicky.
  5. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Remove the headlight knob. Put a plastic bag over the assembly, (to catch the spring-loaded detent ball). Hold the knob and hold the stalk and pull the knob straight off. Look at the soldering on the contacts and make sure they are totally intact. There are two types of contacts inside the knob. Wrap around (earlier models) and two copper blades that pinch together. Clean the contact areas with very fine sandpaper.
    When you reassemble it, put some grease in the hole where the detent spring is and place the ball on the grease, take the knob and line up the molded line on the knob with the scribed line on the stalk. This is the proper alignment. Sometimes, the ball will shift when you put on the knob and you won't get a "click" or positive feel of the detent. Once assembled, check for continuity with a meter.
    Check the switch for hairline cracks where the metal stalks enter the plastic contact holders.
    If there are no cracks, I'd suggest a good cleaning. First, use a toothbrush and some mineral spirits to remove the grease from the contacts. Then use some very fine sandpaper to clean the contact surfaces to remove any oxidation. The bottom, round contacts can be cleaned by moving the stalk first toward the inside, which exposes half the contacts, then towards the outside, which exposes the other half.
    The upper contacts are spring loaded and push against the round contacts. Again, a very fine sandpaper should remove any oxidation.
    Once the contacts are clean apply a light grease to allow the spring loaded contacts to operate smoothly as they move over the round contacts and to prevent further oxidation.
    You can also degrease and clean the horn contacts. (Several different versions)
    Clean the spades at the 3 connectors and clean the corresponding female connectors to insure good electrical contact.
    When you reassemble the inner part into the black housing pull the cable little by little until the switch settles in the housing, then secure the two screws and wave washers.
    NYC Fred and bitsobrits like this.
  6. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    My headlamp stalk has a couple hairline cracks. The first picture is the top and the second one is the bottom. Not sure what to do but not losing sleep over it.
    The aim this weekend was cleaning the contacts for the turn signal and I was able to do that. Seems better in the garage. Will find out for sure on the road.
    Can tell you what NOT to do. Do not install the ring nut unless the horn wire is safely put away. I thought mine was in its "cubby" but apparently it was not all the way clear as the ring nut shredded it halfway. Briefly considered a "HORN BROKEN WATCH FOR FINGER" bumper sticker but thought better of it so I cut the wire and installed a new end on it.
  7. jmaienza
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Pretty standard repair for the horn wire
    Now that you know about the headlight stalk cracks, you can monitor it to see if it becomes more loose. If it gets worse, the loose movement of the stalk will not fully move the pivot head/contact holder and headlight function will be compromised. Always move it with care.
    Verell at unobtainiumsupply,com can mold new parts and rebuild it if it totally fails.
  8. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
    waymar likes this.
