Steering column switch removal | FerrariChat
Discussion in '308/328' started by Ehamilton, Nov 19, 2023.
  1. Ehamilton
    Ehamilton F1 Rookie Rossa Subscribed
    Jun 13, 2010
    2,653
    Durham, NC; USA
    Eric Hamilton
    '81 308 GTSi, the inboard end of the headlight stalk has broken off inside the housing, so the plan is to remove the entire column switch assembly and send it off to @Verell.
    Picture below shows where I am with the removal so far: Everything taken off and the switch assembly separated from its housing. But the assembly still can't be removed because the wires are threaded through the opening in the housing and the connectors are too big to fit through that opening.
    So.... Is there an an easy way to remove that housing, or do I have to remove the wires from the connectors?
    (Last time I this had apart I did the wires, I'm looking for an alternative this time around)
  2. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Unscrew the housing and send it with the switch. Verell can easily work around it.
  3. Ehamilton
    Jun 13, 2010
    2,653
    Durham, NC; USA
    Eric Hamilton
    What is involved in unscrewing the housing?
  4. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,814
    Cerritos, CA.
