Steering hub puller? | FerrariChat
Discussion in '206/246' started by cls, Jul 17, 2019.
  1. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Is there a hub puller available? Looks like my hub has two 6mm threaded holes which could be used to pull it. Otherwise, what's the method? Image Unavailable, Please Login
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,602
    Toronto / SoCal
    Rob C.
    You want to use a puller like the one below and attach pulling bolts to the 6mm holes. Install the puller add a bit of tension to the pulling bolt and then give it a sharp tap with a metal hammer. The shock will release the steering hub. Do not just keep tightening until it comes off. Image Unavailable, Please Login
    DO NOT use a hook style puller that grabs onto the outside of the steering hub body. These will likely bend the hub.
    Another tip is to leave the nut retaining nut on the steering shaft just loose. This will catch the hub when it releases.
  3. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Thanks. Puller on order. Saves me the trouble of making one.
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,162
    Norfolk - UK
    Tony
    Squirt a little release fluid on the splines, leaves for a few minutes then pull it off by hand applying equal pressure around the hub, most come off without the need of a puller.
    Slight tapping with a raw hide hammer around the hub helps if its not playing ball
    Tony
  5. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    I gave it some encouragement with the wheel attached, but it wouldn't budge. I think the nut was overtightened, it was a ***** to remove.
    Rather than lose front teeth trying, I just went ahead and bought the tool.
  6. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,792
    Southern California
    TonyL likes this.
  7. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Much nicer than I would have come up with.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,162
    Norfolk - UK
    Tony
    You will damage the steering wheel if you try to pull it off that way & teeth!!
    Its a splined shaft with keyway so shouldn't need a puller, sometimes they need a little extra to shift it. If you have purchased a puller then that will do it nicely but you will see when you use it, it will take minimal force to move.
    Tony
  9. racerboy9
    racerboy9 F1 Rookie
    2,632
    My 2 cents: You could plug the steering shaft hole and heat the aluminum with a hair dryer. The expansion and some wiggling might get it off. As said before, I would leave the nut on a few turns so the wheel won't slap you in the face if it breaks loose.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  11. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    synchro likes this.
