348 - Steering Rack Bushes | FerrariChat
348 Steering Rack Bushes
Discussion in '348/355' started by m.stojanovic, Nov 29, 2019.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    2,753
    Malaysia - KL
    Miroljub Stojanovic
  2. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    None of those look correct. I fond a fiat one on a site I believe would have worked but I lost all my bookmarks in an incident. I think I have one in Delrin somewhere that I made that I did not use if you want it shown below in black.
    You can see my bushing completely disintegrated. When you replace it with the tie rod ends and control arm bushes the cars is amazing.
  3. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    I think Miro is talking about the 4 mounting bushes to the bulkhead not the internal item which breaks up.
  4. Ferrarium
    5,631
    Central NJ
    Eric
  5. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,711
    Atlanta, GA
    Steve D.
    I bought a bent rack for engineering exploration. It has good bushings that i'm saving for another day.
    I have to get in there and re-examine solutions for the rank end bushing.
    sjd
  6. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
    It would be great if you could take measurements of a mounting bush (biggest diameter, smaller diameter and length) and post here.
    Pangea likes this.
  7. Ferrarium
    5,631
    Central NJ
    Eric
    #7 Ferrarium, Nov 30, 2019
    I redid my rack in the spring the bushings are infact cone shaped. Worst comes to worse I can machine them from Delrin. I'd check bushing used on fiats too they used very similar TRW racks.
    Here is a picture of them when I was popping them out, (second picture) they are a taper fit. A steel washer sits int the recess hole where the press plunger is, I was pushing out the sleeve that goes through the set.
    Real similar to the Integra the 348 ones looked exactly those these shown directly below (not sure about dimensions) - Energy Suspension 16.10103G. I bet there is match out there somewhere...
    Some Toyota ones tapered also. I bet existing taper busing's can be trimmed too...
  8. steved033
    Apr 12, 2017
    7,711
    Atlanta, GA
    Steve D.
    hm...what's your rack number? my junk rack ones are top hats.
    sjd
  9. Ferrarium
    5,631
    Central NJ
    Eric
  10. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Whiteline or Energy Suspension should be able to easily supply the mount bushings. Just need to get some dimensions and give them a call.
  11. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
    Very interesting, the Toyota bushes (which Toyota and what they are for?). They look very similar to the genuine 348 ones:
  12. Ferrarium
    5,631
    Central NJ
    Eric
    Not sure which one the partial part number is there.
  13. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
  14. Ferrarium
    5,631
    Central NJ
    Eric
  15. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    That Midwest Bayless bushing will not fit our racks.
  16. steved033
    Apr 12, 2017
    7,711
    Atlanta, GA
    Steve D.
  17. Ferrarium
    5,631
    Central NJ
    Eric
    Yes I was suggesting to call them and see what they say...
  18. Ferrarium
    5,631
    Central NJ
    Eric
    I think the later boxes used a different bushing. Ricambi does not show a part number for those.
    Here is Ricabmi picture for 89-92.
    Here is Ferrari Part 135139 I bought from Ferrari. When I get home I'll post detailed pics and dimensions. A picture I have on my phone below sorry it sucks I'll get better ones next weekend when i return from travel.
    REAL similar to the Toyota one.
  19. Ferrarium
    5,631
    Central NJ
    Eric
    I wonder if the sway bar bushings fit? They were the same shape, see mine below from when I replaced all the bushings.
  20. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Reached out to them earlier this year; they don’t have any solutions for that particular bushing. Didn’t discuss the mount bushings with them though.
  21. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    712
    Treasure Coast Florida
    MATT
    Very interested to see which direction this thread goes but I will tell you I replaced my bushes in my old 328 a few years ago. They look identical to the 348 ones just a different color and a whole lot cheaper than $106 a piece!
  22. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
  23. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
  24. Ferrarium
    5,631
    Central NJ
    Eric
    I actually have 4 new bushes. Awitalin is down road from me. I can go compare the bushes in person in a few weeks if you want.
    Sent using FerrariChat.com mobile app
