Steering rack maintenance | FerrariChat
Discussion in '308/328' started by Portofino, Mar 25, 2020.
  1. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    916
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    The top image: basically, adjustment shims.
    Lower image: can't tell what exactly this is a photo of. Is that the evaporator drain tube?
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
  4. Portofino
    Sep 17, 2011
    916
    Portofino
    Yes ,the AC drain tube .The other thing Is a mounting bracket .
  5. Cirorsi
    Cirorsi Formula Junior
    790
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    Thor, how do you like that fast rack?
  6. chris_columbia
    chris_columbia Formula Junior
    880
    Columbia MD
    Chris
    If you are in there, you might consider replacing the 8 bushings that mount the rack to the frame with something stiffer. Do a search. A few of us have switched to acetal.
  7. jha328
    jha328 Rookie
    May 26, 2013
    18
    Australia
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I do like it, but I've never driven a 308 without one. (So, cannot objectively say how much/if I prefer it.)
  9. Portofino
    Sep 17, 2011
    916
    Portofino
    Thanks very much guys , that’s very helpful
  10. Nino1964
    Nino1964 Formula Junior
    302
    North Georgia
    The shims can be purchased from Superformance. Not sure of the exact procedure for proper shimming procedure. Maybe someone can advise?
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,232
    Norfolk - UK
    Tony
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    These racks are install and forget items. There are no regular maintenance other than …
    1) If the boots crack, replace them.
    2) If there is a leak, rebuild the rack.
    3) If there are binding issues, replace the rack.
    The changing of the shims is done at the time or rebuild or at the factory. You really don't need to or should even mess with it.
    Crowndog and Rifledriver like this.
  13. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    Disassembly and reassembly/rebuilding the rack is also necessary if you want to install the fast ratio rack/pinion internals from Superformance. I don't believe anybody sells a fast ratio assembled rack?
  14. yelcab
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    That would be true, but that is not regular maintenance. You are essentially building a different rack. The shims affect the effort it takes to turn the steering knob. There is probably a spec, or adjust by feel for someone who has done a hundred of these.
  15. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I'd done shim adjustments on mine. Perhaps I shouldn't, but I've gone from a car that was incredibly difficult to turn to one that's completely manageable. Preload, in my opinion, was set far too high.
    (I'll note for the record that the original install of my rack was completely, utterly screwed up by another mechanic.)
  16. Nino1964
    302
    North Georgia
    I set the shims as part of the rebuild. Shim height that is shallow in very tight rack.
