Steering rack - replace or refurb?? | FerrariChat
Discussion in '456/550/575' started by belfry, Oct 21, 2024.
  1. belfry
    belfry Formula Junior
    May 14, 2015
    464
    Robert Batt
    I am based in the UK.
    My 1995 LHD Ferrari 456GT has play in the steering rack. I was advised to replace it.
    1. Does anyone know of a used left-hand drive 456 steering rack for sale?
    2. Is it possible to refurbish this steering rack with play on both sides? If so, does anyone have any recommendations or experience of this?
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,860
    MO
    Omar
    I bought a refurb for my car from AWitalian; so far so good? Note there are technically 3 different versions: early 456GT, 456M, and 550/575. The latter is by far the best/tightest however the pipe arrangement is slightly different in terms of the connectors between the models. I do not know if you can swap GT racks with M or 550/575 racks as I never fully researched it.
    Before you go crazy and change the rack double check your tie rods and bushings/ball joints are all ok...
    Ferrari55whoa and 308 GTB like this.
  3. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,591
  4. Aerosurfer
    Aerosurfer Formula 3
    1,792
    Indianapolis
    Nick
    Did you replace the ball joint too or were you able to get the inner unscrewed with the steering joint in place?
  5. marce
    marce Formula Junior
    Jan 30, 2014
    453
    Australia
    Marcel
    fairly certain the tie rod ends for the 550 use the same part as a Mitsubishi, from memory it cost $20 , 10 years ago
  6. Aerosurfer
    1,792
    Indianapolis
    Nick
    Go on... would love a link for that price
  7. marce
    Jan 30, 2014
    453
    Australia
    Marcel
    sadly, it was the guy who I bought the car from, he got his tech to match the part.
    m
  8. belfry
    May 14, 2015
    464
    Robert Batt
    I did replace the inner tie rod on one side 6 months ago. I found (from this forum) that Saab parts would fit.
    The Saab part needed the adjustment thread extending by 1 inch, but this was fairly easy to arrange.
    I will get under the car to look for play in the inner tie rods before spending any money.
  9. greg246
    Jun 2, 2004
    26,591
    I replaced the outer tie rods as well, they came off first and then I could get to the inner (steering) rod. Here’s another pic of the inner rod in place showing the wear. Image Unavailable, Please Login
  10. belfry
    May 14, 2015
    464
    Robert Batt
    I've heard back from the steering rack refurb place that my rack teeth are corroded and worn. It can't be refurbed.
    The company is suggesting a used 575 rack "which is identical except for the ratio". They said that it will fit straight into the existing fixings.
    Ferrari55whoa likes this.
  11. Auraraptor
    Sep 25, 2002
    13,860
    MO
    Omar
    550/575 rack is a big upgrade. I swapped mine for on the 456m for that very reason.
    I could have swore there was something slightly different about the GT rack.
  12. Auraraptor
    Sep 25, 2002
    13,860
    MO
    Omar
    I should clarify the previous statement… Something different beyond the steering ratio change in terms of hoses.
    Turns-to-lock: 550 2.2 v 456 2.5-2.6 (GT v M)
    PN: 174950 456m v 170858 550/575
    PN: 161872/15500 456GT
  13. belfry
    May 14, 2015
    464
    Robert Batt
    So I bought a used but refurbished 575 rack. From the parts diagrams it looks like there is a hose that I’ll need to change to get the 575 rack to work on my 456 GT
    for the 456 I already have:
    157350
    PIPE FROM PUMP TO STEERING BOX
    to make the 575 rack work I’ll need:
    170860
    I might need a different union too.
    Has anyone done this? Or can anyone confirm that my thinking is correct?
  14. belfry
    May 14, 2015
    464
    Robert Batt
    So the 575 steering rack arrives later this week. I'm told that it will fit without any modifications. I will keep you posted if this is reality!
  15. tazandjan
    39,020
    You will likely have the most agile 456/456M out there. FHP and MSW hydraulic steering ECUs would be in play for a 456M, not sure the connector is compatible with the 456 GT.
    belfry and Aerosurfer like this.
  16. fatbillybob
    Aug 10, 2002
    28,574
    socal
    I had a rack off a 550 I owned and just had the rack rebuilt. No big deal! The hardest part is getting it out of the car.
  17. Auraraptor
    Sep 25, 2002
    13,860
    MO
    Omar
    There is a union difference on the GT from memory.
    I only did a swap on an M… there it was just a matter of swapping over the lines and it was a direct fit otherwise
  18. Auraraptor
    Sep 25, 2002
    13,860
    MO
    Omar
    Been running just that on my 456m for a year. to make the most of the springs though you really need to swap to 550 shocks front and revalved shocks in the rear
  19. belfry
    May 14, 2015
    464
    Robert Batt
    OK. The ferrari 575 steering rack has been fitted today. The 456 banjo and union bolt fitted without any adjustment, literally plug and play. The 575 rack fits onto the same fixings but is apparently "more central" than the 456 rack, so the mechanic made adjustments to the tie rods to adjust.
    I just had the wheels aligned and I'm looking forward to the chance to try it in earnest.
    The 575 rack was sourced and refurbished by the steering rack refurbishment place for £1,100 delivered. The fitting was £150 and 4 wheel laser alignment was £186, so the whole process cost less than £1500. Eurospares charge £4500 for a replacement 456 steering rack. So I get a faster rack and save £3000!
    Auraraptor, Timmo and Aerosurfer like this.
  20. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    645
    Continental Europe
    Sounds great. Well done and looking forward to hearing how you like it.
    belfry likes this.
  21. Auraraptor
    Sep 25, 2002
    13,860
    MO
    Omar
    Wow that’s a great price ! Can’t wait to hear your feedback
  22. belfry
    May 14, 2015
    464
    Robert Batt
    The 575 rack feels more agile and sporty than the 456 rack. It might be a little heavier at low speeds (a good thing), and it feels more 'modern' than the previous rack.
    I drove my FF later the same day and the 575 rack felt more like the FF's steering, without being overlight, like some modern ferraris.
    I am happy!
    Now I need to understand if I have an air leak causing the emissions to change (see my other thread).
    Auraraptor likes this.
  23. Auraraptor
    Sep 25, 2002
    13,860
    MO
    Omar
    I had the same feeling when I swapped mine. Definitely tighter and better weighted. It had much more impact then changing the steering controller but at several multiples of the price, whether its worth it or not is definitely subjective (I thought so).
