Steering rack replacement | FerrariChat
Discussion in '308/328' started by topley, Aug 23, 2022.
  1. topley
    topley Karting
    May 10, 2022
    73
    Los Angeles
    Jay Barton
    Hi All, Replacing the rack in my 308 GTSi and I have a question... how do you line up the rack in its mounts so that the splined shaft is at the correct angle to the coupler at the end of the steering column? Doesn't seem like there's room to leave it loose so I can spin and adjust the angle then tighten down everything when its all lined up.... but maybe I'm wrong?
    Thanks!
    Jay
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    #2 thorn, Aug 23, 2022
    Insert the steering column into the rack. Then snug that connection. That's your basic indexing point. Rack brackets should be loose.
    Next, fasten brackets to frame. Then, tighten shimmed brackets around the rack.
  3. topley
    topley Karting
    May 10, 2022
    73
    Los Angeles
    Jay Barton
    Thanks. This worked better that I expected it.
