Steering Shaft Coupler 3500GT Vig. Spy. | FerrariChat
Discussion in 'Maserati' started by TridenteFury, Sep 30, 2015.
  1. TridenteFury
    TridenteFury Karting
    Sep 28, 2014
    78
    #1 TridenteFury, Sep 30, 2015
    Ciao Tutti,
    What would be the process of replacing the steering shaft coupler??
    My first assessment, was to unbolt the steering box, uncouple its steering arm, then move the whole box forward, so to move the steering shaft forward to create enough space to remove the old shaft coupler and replace it with a new one...
    Motlo Grazie
    Carlito
  2. thecarnut
    thecarnut F1 Rookie
    3,232
    Atlanta
    The Car Nut
    You should not have to touch the steering box. Unbolt the coupler and then gently pull the steering wheel. You probably have to unbolt the turn signal assembly, which comes out very easily, to not risk damaging the self canceling levers.
    Let us know if this works.
    Ivan
  3. TridenteFury
    Sep 28, 2014
    78
    A big Thanks Ivan!! Yes this sounds much simpler...
    By the turn signal assembly, you mean removing the T-sign column switch with its lever ?
    Many Thanks for your precious help!
    Carlito
  4. thecarnut
    thecarnut F1 Rookie
    3,232
    Atlanta
    The Car Nut
    #4 thecarnut, Oct 1, 2015
    The turn signal has a large nut that holds the assembly to the steering column. Just unscrew this nut with your hands and separate the assembly from the column so that the canceling levers do not get damaged as you move the shaft. No need to disconnect any electrical wires.
    Ivan
  5. TridenteFury
    Sep 28, 2014
    78
    #5 TridenteFury, Oct 1, 2015
    Hi Ivan,
    Is this the large nut you're talking about? Sorry, just want to be sure I'm doing the right thing...
    Many Thanks
    Carlito
  6. thecarnut
    thecarnut F1 Rookie
    3,232
    Atlanta
    The Car Nut
  7. TridenteFury
    Sep 28, 2014
    78
