Steering Shake over bumps | FerrariChat
Discussion in '308/328' started by Auraraptor, Jul 14, 2010.
  1. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,091
    MO
    Omar
    Hi guys, I am getting quite a bit of steering shake/giggle over imperfect roads in the steering wheel. On flat smooth roads it is perfect with no play.
    I think its time for a new suspension bushings (front) or is it something else?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,831
    Cerritos, CA.
    Bushings and/or ball joints might be worn out
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Could be a simple wheel bearing adjusment - how you jacked up the car and inspected the front-end before you dig in?
  4. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    #4 climb, Jul 14, 2010
    I replaced the boots on my 308's steering rack and thought i'd aligned the front end myself but it (steering wheel) would wiggle over small bumps. Id gotten used to it and just fiqured i'd need a front end rebuild someday.
    Long story short a friend of mine who works at an alignment place said he'd align the car and he did and now it's tight as a drum even over bumps...did the same thing for my 300zx that was sloppy and at times would drift in the direction of a crack or depression in the road.
    I'm now a believer in front end alignments.
  5. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    Front shock absorber knackered?
    I had exactly this symptom on my Mondial and when I removed the front shocks the O/S one was shot.
  6. brook308
    brook308 Formula Junior
    Oct 19, 2007
    346
    SS Coast, Australia
    George
    Also check that all the joints in your steering column are tight.
    Have a friend turn the steering wheel while you get under the dash and watch each joint for play. My 308 had some play on centre and it was as simple as tightening the steering boss nut and the pinch nut on where the column joins the steering rack.
  7. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    Replacing all my front suspension bushings made an amazing change. The front of the car used to move all around driving up the curb to my driveway, now it's smooooth.
  8. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Passenger side steering rack bushing. Common problem.
  9. Papa Duck
    Papa Duck Formula Junior
    Jan 16, 2006
    351
    Las Vegas, NV
    Carl
    +1. I just had all of my bushings replaced and it made all of the difference. Over the years I just got used to it being sloppy, but now no more steering wheel movement or shake.
