Steering shake with QV replicas | FerrariChat
Discussion in 'Technical Q&A' started by BillyD, Jun 14, 2010.
  1. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    Every since I put the QV replica wheels on my 308GTB I get a steering shake around 70mph. I figured I had something loose in the suspension but after rebuilding it & the steering the shake was still there. I put a dial indicator on the outside of the rim & found I have almost 30 thousands runout as I rotate the wheel, the high & low are exactly opposite across the wheel like the hub was machined wrong. Can this just be resurfaced?
    Anyone else have this problem or a solution?
    Bill
  2. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    did you get the aluminum centering rings with the wheels?? there should be info on this topic already. i had the same problem with the wheels, the centering rings took care of it.
  3. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    Yes on the centering rings but they are plastic from Superformance in UK.
  4. mwr4440
    58,067
    Bavaria, The 'Other' Germany
    Mark W.R.
    Bill,
    Did you install them?
    I did just for the heck of it and have no issues from Zero up past 130mph.
  5. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    The runout is on the face of the rim(ie the rim moves left & right as viewed from drivers seat), I don't think the centering rings can cure this.
    Bill
  6. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    This is why you dont by reproduction QV rims. This is why I sold mine right after I bought them, paid the piper and got real ones.
  7. flyguyskt
    flyguyskt Formula Junior
    Sep 22, 2009
    443
    South Dakota
    sean
    sounds to me like you simply have a wheel out of balance. take them in and check
  8. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Bill,
    .030" of run-out is a lot and certainly would contribute to your "shake". However, before I'd condemn the wheels, I'd check the run-out at the wheel bearing hub. This should be less than a couple of thousanths...
    If all measures true, short of replacing the wheels, a good machine shop should be able to true them. Another option would be to find a tire shop who has a Hunter "road force" type balancer. I've had great surceases with these machines.
    Best,
    David
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    In deed. take a lot of measurements, and if the hubs/rotors are true and the bearings round and smooth, demount the tires, and have the interface of the wheels machined true. You cannot balance something that is not true.
    Or send the wheels back as defective.
  10. BigTex
    79,406
    Houston, Texas
    Bubba
    Maybe have some metal centering rings???
    I think '308GTB' had some made, they were better than plastic.......
    It could be your steering rack showing some wear???
    Still, if you are seeing it 'at the wheel'...it's the wheel!!!
  11. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    #11 BillyD, Aug 1, 2010
    And the prize for figuring this out goes to BROOK308 tho it was from another thread that he mentioned checking the steering shaft & joints. The lowest knuckle/joint was loose. Why this only showed up with the QV wheels & not the original 14 inch donuts I have no clue!
    Thanks to all
    Bill
    ps now can someone help my old body get in & out of lowered 308 or will I have to buy a 550
  12. thecarreaper
    thecarreaper F1 World Champ
    18,125
    Savannah
    glad you found it, i have had 3 sets of those replica Qv wheels and not had any problems with them. i will definitely continue to use them.
  13. afterburner
    afterburner F1 Rookie
    3,501
    Switzerland
    Urs STEMMLER
    I have a set of Superformance replicas (with plastic centering rings) in my Mondial QV and no issues.
  14. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    No problems with the superformance replicas. Just for the heck of it I put a couple on my lathe and measured the run out with my dial indicator - got 1 thou on one and zero thou on the other. With that measured, I didn't bother with the rest!
    The originals are very nicely made and a couple pounds lighter, but at least with the repro 16s you know you've not dealing with 25 years of potholes and curb crashes....
  15. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    That's great, but............what about the .030" run-out? What's causing this?
  16. BigTex
    79,406
    Houston, Texas
    Bubba
    It's a very good idea to inspect the old castings periodically.....and quit hitting the curbs....:rolleyes:
  17. chris marsh
    chris marsh F1 Veteran
    5,767
    Detroit
    Chris Marsh
    #17 chris marsh, Aug 3, 2010
